5 Pages <1234>»
Tamiya 1/12 Ferrari Enzo + PE by Dominic Options
#21 Posted : 02 January 2017 10:30:31
Great start, it looks a great model to work with.BigGrin
#22 Posted : 02 January 2017 11:28:40
Nice start to your build.BigGrin
michu
#23 Posted : 02 January 2017 12:53:00
Good start! Be careful with the tubing that goes to fuel rail or whatever that is (an array of thingies attached to the end of engine block and painted blue). Best to dry fit the tubing and see if it goes easily on before you attach the other ends to engine. Scrap the paint if you have to. Otherwise it will be very dificult to install and you can damage the flimsy mount points for this blue part.
Have fun, this is a lovely kit to build!
Happy building :-)
forgotmylogin
#24 Posted : 02 January 2017 14:03:03
Thanks for the comments guys.
arpurchase you are right, thats due to there being such a temperature difference in there. I think once Spring gets here I am going to have to strip out and add some insulation.
Mt brother is going to love me LOL
michu thanks for the advice...I've been looking at that step and wondering the same thing myself.
#25 Posted : 02 January 2017 15:00:46
Nice start Dominic to what looks like a very interesting build, will be following this with interest and good luck in the competition. Cool ThumpUp
forgotmylogin
#26 Posted : 02 January 2017 17:35:15
Day 2
Step 1 (cont) & 2
Hello.
Today I continued from yesterday working on the main engine block, and a few other associated parts. I thinned down and used Tamiya flat aluminum in the airbrush, which went on in 2 quick coats, allowing about 30 minutes drying time between each.
Before I went any further with this I wanted to wash the block to add depth. I wanted to use Tamiya Smoke thinned down a little, but apparently I don't have any. So I just used flat black thinned down a lot. Brushed on quickly and wiped the excess off with a Q-tip. You can see a with/without photo below, quite like the affect myself since I am going for an almost-new look rather than a never-been-run showroom look.
Left side without:
Right side with:
While this was drying off, I made a start on the other parts that fit directly onto the engine block, and started detailing the drive belt assembly which was, dissapointingly for this kit, a single part.
And in between, doing the other engine parts, fitting and picking out the various details gradually.
And everything worked on today fitted in place and a few more little touches here and there, along with the first of the cables added...
I've got the parts for the exhaust system soaking in foam oven cleaner to strip the chrome plating off, which I absolutely hate on kits with a passion. I will leave them to to soak for a while and rinse them off later, and repeat as needed.
Tomorrow (or later) I need to go back and change a couple of details, and add the PE parts which I almost forgot about Blushing
Thats all for today, thanks for reading.
forgotmylogin
#27 Posted : 03 January 2017 20:27:34
Day 3
Step 3 - 5
Hello folks. Hope we've all had a good day.
I've made a little more progress on this, not a great deal though.
First off, I fitted the heat shield for the gearbox and some more of the cabling etc. For the heat shield I used Alclads chrome, but applied heavier than it should be applied to get a dull,dark look. Then added some orange/burnt hints using a weathering kit.
Next up, was those exhausts...this is how they looked after the chrome plating had been fully stripped off and they had been assembled ready, and a quick test fit:
So on to chroming them. I was really hoping this would turn out well, as it could look awful if not. So, to start with, a gloss black base coat:
Followed by the first chrome coat:
Not too bad. I could have stopped there, however I found it a little too dark and wanted a brighter look to start with, before I weather them back dull again. It's really tricky to get a bright chrome look (as using a dark base coat) and so easy to over do it and loose the affect permanently. Thankfully I got it about right. (It's not quite as bright as the photo looks, the light caught it just right):
Now all that was left to do was to weather them down and add some orange/burnt highlights and a few blue areas too, along with the decals and fit to the enging block. In between doing this, I remembered the PE set included manifold parts, so sprayed and fitted those as well, as can be seen in some of the photo's below:
One final thing for today, I fitted the PE part(s) for what I assume is the oil drain plug...
And thats me for today, thanks for stopping by.
#28 Posted : 03 January 2017 20:39:32
Well you're certainly cracking on with your build Dominic and it's looking really cool. Love what you've done with the exhausts and the hot metal look has come out very well indeed. Reminds me of the fun I had creating the same effect on my Deag 1:8 McLaren MP4/23 using the same techniques.
Very well done, a good day's work. Looking forward to your next update already. Drool Cool ThumpUp
forgotmylogin
#29 Posted : 04 January 2017 19:19:42
Thanks Kev. The affect is only subtle, but it's enough.
I still need to work on that technique of chroming and try other products. Next build I will try for a "never used" look...
Day 4
Step 6 - 7
Good evening.
Next tash was the air intakes and the plugs. This was one of the parts of the build I was looking forward to so wanted to get this done well.
First job, was to get the distrubutor looms ( ? ) sorted, along with the air intakes and plugs primed:
And painted:
The paint was still wet at this stage so they actually look awful close up. Next was the intakes and plugs:
Whilst all that was drying off, I cut the various lengths of vinyl tubing, and fitted the smaller distributor to the cables already attached. I then proceeded to fit the new cables along with their plugs before gluing the distributors in place:
And finally, was a case of fitting the intakes and attaching everything. Plenty of pics of this because I love the level of detail in this section and the fact that my camera now seems to be able to take really good pics upclose BigGrin
That's it for today. Tomorrow I will be doing some work on the valve covers and, if my airbrush arrives, the rocker covers as well.
Thanks for looking in.
usersteve83
#30 Posted : 04 January 2017 19:27:45
Loving your work so far, nice attention to detail. Looking forward to your next update
Built- Shelby Mustang, Lamborghini Huracan
Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
#31 Posted : 04 January 2017 19:28:24
Looking fantastic already!!!
#32 Posted : 04 January 2017 21:35:11
This is coming along really well, some nice detail in the kit. BigGrin
#33 Posted : 04 January 2017 22:10:01
BigGrin What undercoat and top coat did you use on the air intakes DomCool
#34 Posted : 04 January 2017 22:11:06
Another nice update from you Dominic and looking good, well done. Cool ThumpUp
Is that one of those amazingly cheap 'ProArte' size 10/0 fine detail brushes (in photo #3) from an Ebay seller that I recommended recently on the forum by any chance? If it is, how are you finding them to work with Dominic?
forgotmylogin
#35 Posted : 04 January 2017 22:43:53
Thanks for the comments guys. BigGrin
Kev yes they are, thanks for recommending them! I have to say they are great to work with, all except the smallest brush. I find that getting enough paint on them to actually do anything, it clumps into a little ball half way up the brush, but that just might be me. The rest are perfect. Cool
arpurchase undercoat was Zero's white primer/microfiller, and top coat was just thinned down Tamiya XF-16 flat aluminum.
Cheers
#36 Posted : 04 January 2017 23:10:34
BigGrin Ah thanks for the paint info as I thought you had used a Textured paint as an undercoat to get the grainy effect as you did mention that you intended to use one on the build.Cool
#37 Posted : 04 January 2017 23:25:31
You're making some good progress with this and doing a rather good job too Cool I love how the chrome turned out, looks just right Cool
Great job ThumpUp
forgotmylogin
#38 Posted : 05 January 2017 11:09:37
Ah I get you now. No the textured paint I referred to was going to be for the interior, an alternative to flocking. But not sure as when I tested that paint it killed my airbrush Bored
As for that textured look...to be perfectly honest I am not sure where that came from, well no, I know where it came from; was the undercoat, but it wasn't intentional and certainly something I need to find out why as I plan on using that same undercoat for the body Confused
It's possible temperature was an issue.
#39 Posted : 05 January 2017 12:01:56
If you are painting in very cold or damp ambient conditions, then its going to have an affect on paint finish. You seem to have a fair amount of moisture in the compressor trap shown in post #15, which is an indicator of a high level of damp in the air, which might indicate the cause of the paint finish problem.
forgotmylogin
#40 Posted : 05 January 2017 13:29:19
Thats not going to be an easy fix.
I may have to move my airbrushing back into the house, that will please my missus no end LOL
5 Pages <1234>»
This page was generated in 0.244 seconds.
