Joined: 27/02/2016 Posts: 138 Points: 429 Location: milton keynes
Ok Someone's got to kick this thing off Still waiting for my first subscription issues to arrive but picked up a copy from my local tesco this morning when i popped in for milk Not a lot to look at or do in the first issue but one thing that's obvious is the improvement in the feel/quality of the parts from the test issues earlier this year Bobbaf3nn attached the following image(s): Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
a look at the parts included in issue one R2-D2’s Head and Right Leg Parts with this Issue: LED Cluster for Processor State Indicator LED Cluster Power Lead Fixing Screws x 3 LED Cluster Mounting Processor State Indicator Lens Processor State Indicator Faceplate Primary Photoreceptor Faceplate Right Shoulder Plate Fixing Screws x 6 and the screwdriver Please note: The two black fixing screws indicated in the issue 1 parts list are not included with this issue..were advised on the back of the blister pack that they will be supplied @ a later date Bobbaf3nn attached the following image(s): Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
fit the LED Cluster into the LED Cluster Mounting so that the three pin sockets match the three screw holes and then screw them together using the 3 black fixing screws Bobbaf3nn attached the following image(s): Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
remove the wire holding the power lead together You will notice that there is 2 different plug sizes.. we want the smaller one to attach to the cluster to the control circuit Simply press it together until it clicks firmly into place And that's it for issues one just need to put away until next issues arrive Thanks for looking guys ... Have a great 2017 Bobbaf3nn attached the following image(s): Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
Nice to see a build underway, well done. Graeme
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
great start, hoping to get mine started soon now christmas is nearly out the way.
Great to see you up and running on this Al
 Nice start and enjoy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Congratulations on being the first to post a build diary
Great start, nice to see a diary get going for this one.... Regards Alan
Great to see the first build diary, have fun and I look forward to seeing your progress. Regards Markwarren (Mark) Admin
Like you said someone has to start things off. Enjoy your build. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Well done for having the first build diary, looking forward to following your progress.
Ok finally got round to completing issues one to four with some simple before and after shots to show the progress to date Plan to add more photos with future issues Nothing you haven't seen before and right now planning on going out of the box look although i'm impressed with some of the weathering some of you guys are achieving   Issue 2  Issue 2 complete Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
Issue 3  Issue 3 complete.. Blue section only test fitted as per instructions  Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
Finally Issue 4  Few more bits test fitted until told otherwise Blue LED test  Red LED test  And back into the box until the ext delivery comes 4 down down 96 more to go Regards David Current builds: Eaglemoss DeLorean, Deagostini R2 D2 Build
Great to see you up and running, looks great. Regards Markwarren (Mark) Admin
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 23/01/2017 Posts: 62 Points: 186 Location: Livingston
Looking good! I've only got the first 2 issues so I haven't started mine yet but as soon as my next delivery arrives the build will start!
your build is looking very good, got the first four issues, have not started the build yet, keep up the good work.
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
Love the before and after photos. DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
