Joined: 03/10/2014 Posts: 40 Points: 109 Location: aberdeen
Hi folks,after a couple o deaths in our family mine and Keelans build has been layed half built for last 6months,is there anything that we should do b4 restartin build ie strippin greased parts/rebuild engine or should everything b ok to continue.
Many thanks Steve and Keelan
Hi Everything will be fine to carry on where left off. If only half way through then you won't have had the engine running so will be just fine. Sorry to here of your losses. Hope your build gets underway. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks for reply magpie,thought it might be but just wanted to check b4 restart build
