in my case the colour changes from full thickness down to about a quarter thickness and then gets thicker again, so I cut a piece to the thinnest point, next I marked this piece at the point it changed colour (arrowed pic 3) File Attachment(s): willz attached the following image(s):
next I glued a walnut strip from the pencil mark at one end and to the corner at the other, then left to set, after glue set I`m left with my piece with the excess walnut overhanging, with my saw still set for the width of the second planking strip I simply put it thought again to remove excess walnut, my next step was to glue a strip of boxwood up to the walnut and leave to dry,, (phew) again when dry through the saw it goes to remove the excess boxwood, this leaves us with a double thickness planking strip that changes colour, the colour change on the strip is straight because they are both machine edges together,, but when you glue it up to the first thin planking strip it will curve, one last point, I usually use titebond glue but for this I used pva, simply because its not as brittle setting and we dont want the bits popping off when curving into place willz attached the following image(s):
finished piece willz attached the following image(s):
dont know if i pulled that one off explaining willz attached the following image(s):
heres the finished piece in position (arrowed) willz attached the following image(s):
Hi Willz, took me a couple of reads but managed to follow what you were doing.... great work and looking superb..... Regards Alan
Hi Willz. Another nice update. Great work looking superp. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 29/03/2011 Posts: 1,053 Points: 3,165 Location: Glenvista JHB
Hi Willz Lovely update. Really enjoying your methods. Thanks for sharing. Kind regards, Garth "Measure twice, cut once!!!" Finished!!! HMS Victory, Current build: Black Pearl. On hold: Bismarck, Golden Hind, Flying Scotsman, Victory Cross Section, SOTS, Tiger 1. Wish list: USS Constitution.
cheers lads appreciated,, whilst finishing off the bottom wale decided to finish a gun port just to see the affect. quite pleased with it, the mahogany linings is about as good and i can get to the red inner gunports, but overall pleased willz attached the following image(s):
 Great job on the gunports Willz Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
First class Willz, gun ports look brill... Regards Alan
Stunning work Willz. The gunports look just the job. Your doing an amazing job on her. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
cheers lads appreciated, as i continued making up the bottom wale it was impossible to keep the walnut stock all the same colour, as you can see by the pic the individual pieces dont match, this is the problem you get when you buy your timber at different times, so a lesson learnt, on the bright side it will inform the viewer of the intricate construction of the wales. hope everyone is having a great time at this time of year, cheers lads i`m off for a beer willz attached the following image(s):
This looks really great work Al
cheers Al ok wanted to finish the wales on port side this year, managed to finish them but not all the gunport are cut out yet, the last piece was being awkward so had to give it the rubber band treatment !! (it wont try that again  ) happy new year to all willz attached the following image(s):
Joined: 10/03/2016 Posts: 73 Points: 222 Location: ASHFORD KENT
Quality work , great build
Hi all, hope everyone had a great time over the festive season…. On with my build, finished the bottom wale on the port side and was completing the gunport linings, when I noticed a bad colour match on one of the stock shape wale pieces !! kept bugging me so in the end decided to replace it, it was one with the colour change running through it so wasn`t happy, so heres how I did it. Going to do this tutorial is small stages, so first heres a pic of the piece that needs replacing, going to replace the whole stock shape, the wrong colour bit is far too small, so easier to remove in one and make another split colour piece willz attached the following image(s):
 Looking good Willz it's a real pain when you get a different coloured wood sticks out like a sore thumb Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
very true Martyn ok so we dont want to damage anything surrounding our piece so here we go. First of all I always use pva or titebond interior, this allows me to use this method. I cut some kitchen towel the same length and about 4 or 5 time wider, then fold to the breadth of the piece, soak it in clean warm water turn the ship on its side and place the wet kitchen towel over the work. (see pic) willz attached the following image(s):
so after ten mins remove kitchen towel and dig out some bits from the centre of the piece, never go closer than 3 or 4 mm to the edge, trying to dig out from the edges will damage the surrounding work .. after you`ve lashed some bits out of the middle this will reveal some dry areas so again on with the kitchen towel for another 5 mins. Keep repeating this till its removed, when your about 3 mm from the edge you can lift out the piece from its neighour, making sure its loose enough, heres a pic of mine when removed, you can see the marks in the centre that was made with my stanley blade looking at whats left you can just faintly see the pencil mark the i used for the colour change willz attached the following image(s):
