7 Pages 123>»
Heinkel HE111 Zwilling and Messerschmitt Me 321 Gigant diorama Options
#1 Posted : 21 December 2016 23:53:19
These 2 kits form the centrepiece for my entry to build of the year 2017
More pics of the parts soon.
#2 Posted : 22 December 2016 16:06:18
Cool look forward to seeing your build Diary.
Ian BigGrin
#3 Posted : 22 December 2016 21:50:27
Thanks Ian, will soon be Jan 1stBigGrin
#4 Posted : 22 December 2016 23:43:23
This will be interesting to follow.... good luck with it...Cool Cool
#5 Posted : 23 December 2016 01:09:19
This is going to be an interesting build, looking forward to seeing them come together and how your going to display them.BigGrin
#6 Posted : 23 December 2016 11:05:41
A very interesting entry with two amazing aircraft, which should build into an eye-catching display piece. Well done Al, I'll be watching this one. Cool ThumpUp
#7 Posted : 23 December 2016 14:49:56
Thanks guys, hope I do them justice,
#8 Posted : 24 December 2016 15:30:52
Here's a look inside the boxes at the parts, first the Zwilling which has a length of 24cm and a wingspan of 47cm. Not bad for an old kit and even includes 2 stands.
Then a couple of the Gigant. Just to give you the size of this beast its 39cm long and over 70cm wingspan!!
More pics once the build commeces in January.
#9 Posted : 24 December 2016 16:23:26
A decent amount of parts, and the detail looks good on them.BigGrin
#10 Posted : 26 December 2016 11:22:23
Looks like a nice kit, the parts look nice and free of flash for an old kit Cool
#11 Posted : 02 January 2017 19:28:40
Thought I better make a start as it will soon be December 2017 LOL first a little background knowledge of the aircraft.
The He 111Z Zwilling was a design that entailed the mating of two He 111s. The design was originally conceived to tow the Messerschmitt Me 321 glider. Initially, four He 111 H-6s were modified. This resulted in an aircraft with two fuselages and five engines. They were tested at Rechlin in 1941, and the pilots rated them highly.A batch of 10 were produced and five were built from existing H-6s. The machines were joined by a center wing formed by two sections 6.15 m (20 ft) in length. The powerplants were five Junkers Jumo 211F engines producing 1,000 kW (1,340 hp) each. The total fuel capacity was 8,570 L (2,260 US gal). This was increased by adding of four 600 L (160 US gal) drop tanks.The He111Z could tow a Gotha Go 242 glider or Me 321 for up to 10 hours at cruising speed. It could also remain airborne if the three central powerplants failed.
The layout of the He 111Z had the pilot and his controls in the port fuselage only. The controls themselves and essential equipment were all that remained in the starboard section. The aircraft had a crew of seven; a pilot, first mechanic, radio operator and gunner in the port fuselage, and the observer, second mechanic and gunner in the starboard fuselage.
The He 111Z was to have been used in an invasion of Malta in 1942 and as part of an airborne assault on the Soviet cities of Astrakhan and Baku in the Caucasus in the same year. During the Battle of Stalingrad their use was cancelled due to insufficient airfield capacity. Later in 1943, He111Zs helped evacuate German equipment and personnel from the Caucasus region, and during the Allied invasion of Sicily, attempted to deliver reinforcements to the island.
During operations, the He 111Z did not have enough power to lift a fully loaded Me 321. Some He 111s were supplemented by rocket pods for extra take off thrust, but this was not a fleet-wide action. Two rockets were mounted beneath each fuselage and one underneath each wing. This added 500 kg (1,100 lb) in weight. The pods were then released by parachute after take off.
The He 111Z's operational history was minimal. One such machine was caught by RAF fighter aircraft over France on 14 March 1944. The He 111Z was towing a Gotha Go 242, and was shot down.Eight were shot down or destroyed on the ground in 1944.
The Messerschmitt Me 321 Gigant was a large German cargo glider developed and used during World War II. It was developed into the six-engined Messerschmitt Me 323 Gigant.
During the preparations for a possible invasion of Britain during World War II (Operation Sea Lion) it became obvious to the Luftwaffe's Transport Command that there was a need for a larger capacity cargo- and troop-carrying aircraft than its mainstay, the Junkers Ju52.
The Me 263 had a framework of steel tubing provided by the Mannesmann company, with wooden spars and a covering of doped fabric. This allowed for quick construction and easy repair when needed and also saved weight. The Me 263 was redesignated the Me 321 and was nicknamed Gigant ("Giant") due to its huge size.
Its nose stood over 6 m (20 ft) high, and was made up of two clamshell doors. The doors could only be opened from the inside, when ramps would be used to allow vehicles to drive in or out. Compared to the Ju 52, the Me 321 offered a load area six times larger, at around 100 m2 (1,100 sq ft), and could accommodate a gross cargo weighing up to 23 t (23 long tons). The cargo space had been designed to replicate the load space of a standard German railway flatcar, allowing any cargo that could travel by rail to fit into an Me 321. Alternatively, if used as a passenger transport, 120-130 fully equipped troops could be accommodated.
The Me 321 was fitted with a jettisionable undercarriage comprising two Bf 109 tailwheels at the front and two Junkers Ju90 main wheels at the rear and was intended to land on four extendable skids.
Crew: three
Capacity: 130 troops
Length: 28.15 m
Wingspan: 55 m
Height: 10.15 m
Wing area: 300 m²
Empty weight: 12,400 kg
Loaded weight: 34,400 kg
Maximum speed: 160 km/h on tow (100 mph)
Armament
Guns: 4 × 7.92 mm (.312 in) MG 15 machine guns
Well here we go, just a couple of parts assembled so far from each aircraft, firstly the Zwilling.
Then the Gigant, this is going to be a large beast when complete.
Thanks for looking in.
#12 Posted : 02 January 2017 20:22:55
BigGrin Nice startCool
#13 Posted : 02 January 2017 22:00:04
I hope you have instructions and not "winging" it!LOL BigGrin
Great start to your build, looks like it will be a rather large display once finished.Blink BigGrin
#14 Posted : 02 January 2017 22:04:37
Interesting info and good to see this one underway, good luck with the build Cool
#15 Posted : 02 January 2017 22:06:23
Nice start to your build. look forward to seeing your progress Ian.BigGrin
#16 Posted : 03 January 2017 21:14:23
Thanks for looking in guys BigGrin
forgotmylogin
#17 Posted : 07 January 2017 17:16:43
The German engineers certainly came up with some interesting aircraft designs during the last century didn't they... Cool
Good luck
#18 Posted : 08 January 2017 19:24:21
Nice start Al, this is certainly going to be a very large and very interesting diorama when complete!! Good luck in the competition mate, watching with interest. Cool ThumpUp
#19 Posted : 08 January 2017 20:40:58
nice choice of models you have there.
Always considered the Gigant but for one reason or other never in all these years have I actually purchased one so looking forward to seeing this one come together.
#20 Posted : 11 January 2017 23:44:56
Cheers guysBigGrin
7 Pages 123>»
This page was generated in 0.227 seconds.
