29 Pages «<910111213>»
karls new victory build Options
#201 Posted : 22 November 2010 21:37:41
Good stuff, keep the photos coming
willz
#202 Posted : 24 December 2010 00:38:10
karl1113 wrote:
there she blows spruced up and stained walnut.
hi karl i see you have a amati master cutter, can you tell me if the blade is double edged or a single edge please mate, cheers Willz
#203 Posted : 24 December 2010 10:05:09
Its double edged, 'Always Hobbies' have a slightly different version
http://www.alwayshobbies...ti$9Angle-Guillotine.ice
#204 Posted : 24 December 2010 10:06:38
hi willz,merry christmas,this in my opinion is a must have tool,the blade is double edged,but not only that,after you've cut 1000 planks,and it's getting blunt,you turn the blade around not over,you start again,then when that is blunt you turn the blade over,you get four turns in all,before you change the blade,if you noticed ,on my build that Ido 45degree splice joins,that tool doe's it with ease,the reason I do that is,both parts of the splice cover the whole of the bulkheads thus giving you more the adhere to.some of amati tools are worthless(shroud rigger)but this is worth it,straight cuts every time.the blades are heavy duty,and cut the hardest of wood,
#205 Posted : 24 December 2010 10:15:10
merry christmas tomick,I considered that version,but the cutting blade stays fixed,the amati one you swivel the cutter,much quicker,and as the 45degree is at the end of the stop you don't even have to look to see if it's 45 degrees.so I decided on the amati.what I will say at this point is,the cut is slightly pushed in,
as it would be if you used a knife,if you want a true cut you use the razor saw and block,which I use for the thicker wood.
#206 Posted : 24 December 2010 11:50:57
Hi Karl, I have the Amati cutter, and can only ditto what you've said about it, I just highlighted the other version as being a cheaper alternative.
Happy Christmas to you and all the best for 2011
willz
#207 Posted : 24 December 2010 14:17:58
Cheers Karl and Tomick think I may have to invest in one, or a razor saw.
Anyhow a merry xmas to all and have a good un.
Willz
#208 Posted : 24 December 2010 21:13:09
merry christmas guys,get both willz and treat yourself.
#209 Posted : 11 January 2011 20:54:28
this is the effect I'm trying to achieve,using the veneer to make a rebate.
#210 Posted : 11 January 2011 20:55:32
jonny7england
#211 Posted : 11 January 2011 21:24:22
Its looking real nice Karl, I have not got quite that far yet, but the way you have done the ports fires up a few ideas...cheers mate, keep the pictures coming...ThumpUp
Foz
#212 Posted : 11 January 2011 21:53:35
Nice job Karl, your work inspires me. Keep the pics comming
#213 Posted : 18 January 2011 12:08:42
put a few more lengths of veneer on.
#214 Posted : 18 January 2011 12:10:04
#215 Posted : 18 January 2011 12:11:23
Foz
#216 Posted : 18 January 2011 19:09:23
Karl
That looks great, i really like the veneer that you are putting on. I was going to paint mine but after seeing how yours is turning out im having 2nd thoughts and thinking about getting veneer myself now.
Quick question. Are you goining to do the entire hull in the same colour veneer?
Keep up the great work
Foz
Son of Bulwark
#217 Posted : 18 January 2011 19:53:03
Hi karl! Cool
I see you've been working hard veneering, I started veneering the lower hull yesterday and it is going well, you should find the lower hull easier with the second layer of planks mate.
Well it looks like you’re having fun! Keep up the good work! ThumpUp
jonny7england
#218 Posted : 18 January 2011 20:13:19
Hi Karl, that's a damn fine piece of work you've done there mate, keep the pics coming...ThumpUp
#219 Posted : 18 January 2011 20:16:54
yes foz,I'm veneering the lot,painting upper half,varnishesing the hull.but the cutty sark and black pearl slowing me down a bit.Blink
#220 Posted : 30 January 2011 12:34:25
it now needs a good sanding then sealed.
This page was generated in 0.296 seconds.
