2 Pages <12
Hi everyone, I'm very excited about this Falcon, but... Options
scraperjawa
#21 Posted : 29 November 2016 05:52:52
I would also recommend the DOA line of paints. They take a while to get (Several months is not unusual), but are so worth it. You can look at what they offer at http://www.starwars-doa.co.uk/ . Really nice stuff for this model.
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Turbowars
#22 Posted : 29 November 2016 06:13:37
Rank: Amateur Level 1
So do you mean you glue the added detail parts on before or after you spray the base coat on? I ask because it looks impossible to paint the base over all the added detail. So to me it looks like some of the detail can be painted glued on the panels, but some will need to be painted on the spruce then glued on to the painted panels. Which brings up the issue of gluing the parts on a painted surface.
Hmmmmmmm
Turbowars
#23 Posted : 29 November 2016 06:25:05
That paint looks great. Too bad I have already spent a lot on tamiya paints.:(
Turbowars
#24 Posted : 03 December 2016 17:31:16
darbyvet wrote:
I think the cockpit the kit comes with is fine.I wouldnt worry about all the detail sets unless you want every detail to be added.If you get the Paragrafix sets you will need to modify the kit parts and that means cutting and drilling.If you are planning no keeping the ship closed up I wouldnt bother with any detail sets for the hold either.
The reason for painting the inside of the panels black or silver is to help block out any light leaking from the lighting LEds that come with the kit to ight the cockpit,gun turrets and engines.If you dont paint the inside of the panels you may see some light leaking through the hull when you turn the lights on.
Some builder are just building the kit as it comes.Some are adding one or more detail sets to enhance the detail and some are scratchbuilding new parts etc...
Do what makes you happy.If you want something good to look at and you dont need everything detailed to the max just build it with no extra parts.IF you want to go all out on detailing buy the extra sets, but be prepared to add quite a bit of extra work to get them to fit and look good.
Carl clear your PMs
#25 Posted : 03 December 2016 17:42:35
PM inbox cleared MAtt
2 Pages <12
This page was generated in 0.101 seconds.
