John PassmoreThreading the wood blocks Options
John Passmore
#1 Posted : 22 November 2016 06:07:14
Hi everyone - I'm back from my long sojourn around UK and France and have just recently unwrapped SotS where it has been hibernating for the past 4 months.
Been getting on with the cannons and having difficulty threading the twine through the holes in the blocks.
Can anyone advise best method?
Thanks and regards
JohnP
#2 Posted : 22 November 2016 06:25:23
BigGrin Hi John there is two ways of doing it Cool . Make sure that the holes in the blocks are clear then you can use a needle threader you can get them from a sowing shop . Or the other option is to stiffen the front part of the thread with CA glue ie super glue. Once dry trim to a point and push through the block Cool
Hope this helps rgd Martyn
Ps hope you had a great holiday BigGrin
#3 Posted : 22 November 2016 10:52:45
Hi John, I have used both methods Martyn has given and both work well. I also find that if the thread is pulled through beeswax first - as many modelers do with rigging thread - this also makes threading blocks, eyes etc. a lot easier.
John Passmore
#4 Posted : 22 November 2016 13:21:15
Hi Martyn
Thanks for the info. I found a needle threader in the wife's sewing box - never seen one of these before...Blushing Gave it a go and works a treat, although it took me half an hour to make the first block and tackle set...Blink Hopefully will improve as I go along...BigGrin
JohnP
John Passmore
#5 Posted : 22 November 2016 13:24:41
Hi Graeme
Many thanks for the tip - although I'm not sure if beeswax is available in Oz...Blink I'll have to look around for it and give it a go...BigGrin
JohnP
AdamHall
#6 Posted : 22 November 2016 13:57:57
Hi John,
Welcome back.
Another option you may want to consider is to use clear finger nail varnish. You can pick up a bottle cheap as chips at Priceline, Red Dot or any other $2 shop. Apply a tiny amount to the end of your thread, twirl into the thread, wait to dry (usually less than a minute), cut the end square and you are good to go. It's the same as using CA glue, but at the reduced risk of sticking your fingers together. You can also apply a dab on rigging knots to help keep them in place.
Food for thought.
Regards, Adam
John Passmore
#7 Posted : 22 November 2016 23:24:34
AdamHall wrote:
Hi John,
Welcome back.
Food for thought.
Regards, Adam
Hi Adam
Thanks for the tip - sounds great and I'll certainly give that a go. I'm not keen on using CA in these tiny applications as I always seem to get some on my fingers...BigGrin
JohnP
This page was generated in 0.135 seconds.
