12 Pages «<9101112>
WW1 Road Locomotive - "captured booty" Options
#201 Posted : 18 November 2016 19:28:09
Hi everyone and thanks for your comments.BigGrin
Wheels are now fitted to the howitzer, transport dolly to do next. Here are some pics of the howitzer, its not finished yet, still got mud and dust to add, but I thought it would be good to show it before and after dirt!.BigGrin
#202 Posted : 18 November 2016 23:58:59
Stunning piece of work Daran, your weathering techniques are simply superb.....Drool Drool Drool
#203 Posted : 19 November 2016 10:19:18
Fabulous weathering as always Daran, it looks very realistic and hard to tell that it isn't actually made of real metal - the finish is spot on!!
Very well done mate. Drool Cool ThumpUp
#204 Posted : 19 November 2016 11:01:13
The gun kit itself looks amazing and your work to transform it is stunning! Well done and very clearly we chose the right guy for the job... Joe is only the driver Laugh, well done ThumpUp
#205 Posted : 19 November 2016 11:06:06
Fantastic build - really enjoyed following along with this one.
#206 Posted : 19 November 2016 11:29:52
Hi everyone and thank you for looking in and your comments.BigGrin
#207 Posted : 19 November 2016 13:47:31
Well. You've done I again Nemesis!
A stunning finish very nicely weathered whilst not being over the top Drool
#208 Posted : 19 November 2016 14:12:38
Hi Dave and thanks for your comment and looking in. BigGrin
I have started on the towing dolly and its wheels. I will give a sort of tutorial as I go, and what colours I use, although it varies from model to model depending on the base colour scheme.
The chips and scratches are done in Tamiya hull red, and using a fine tip brush I pick out high points, corners and bolt heads that would be knocked easily, also high wear areas like handles , towing eyes and linkages. the scratches are done the same way, but very lightly using only the tip of the brush. It needs to be as non uniform as possible, so be as random as you want, just don't go mad as its easy to overdo it! Don't worry about them looking to bold and bright, as you add layers and washes they will blend and soften.BigGrin
#209 Posted : 19 November 2016 19:50:09
I have redone Joe's eyes as he had a bit of a "Thousand yard stare" or "mad axeman" look about him! LOL BigGrin
#210 Posted : 21 November 2016 14:03:30
Hi Darren.
Fantastic job on the weathering on the gun. look forward to seeing more of this one.
Ian Cool Cool BigGrin
#211 Posted : 21 November 2016 15:21:49
Great job on the weathering and the figure.
#212 Posted : 21 November 2016 16:48:24
So Joe finally got his hands dirty.About time!!! Looks great Nem
#213 Posted : 21 November 2016 19:09:36
So the next step for the towing dolly was to pick out some of the heavier chips and scratches. Again using a fine tip brush I added gun grey over the hull red to give the impression of metal showing through. Next step will be to give everything a light wash of diluted sepia. This will be done over a few coats to build up the desired finish. its easier to add than take away.BigGrin
#214 Posted : 21 November 2016 19:23:22
very nicely done indeed.
That looks a cracking good model you have worked with and such detail on the parts.
#215 Posted : 21 November 2016 20:35:31
The washes have been done and also a pin wash to pick out bolt heads and brackets. Once this is dry I will dry brush with gun grey and then a coat of matt varnish.BigGrin
#216 Posted : 21 November 2016 20:43:05
Love Nice and chipped Nem lovely work Cool
#217 Posted : 21 November 2016 21:08:09
Stunning work Nem Cool
#218 Posted : 21 November 2016 21:21:40
That's got more chips than Harry Ramsdens' chip shop, but they look just as tasty!! Laugh Drool
Very nice work Daran. Cool ThumpUp
#219 Posted : 21 November 2016 22:27:14
Very nice Nemesis and thanks for sharing your scratch technique, it's actually a lot more simple than I thought it would be but such a great effect Cool
#220 Posted : 22 November 2016 17:29:35
Hello all and thanks for your comments. The dry brushing is underway, then a coat of matt clear. Dust and mud will be done on the engine and howitzer together to get it even and the same shades.
The first 2 pictures give you a before and after of the dry brushing on the blades so you get an idea of the effect, it is done lightly so you can build it up on high wear areas. The other pictures are of it all done before the matt coat.BigGrin
Guest (6)
12 Pages «<9101112>
This page was generated in 0.843 seconds.
