 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
thanks all, every home should have one of these.
parts from part 37. stevegbr attached the following image(s):
here are the parts for this build. stevegbr attached the following image(s):
this is the front part of the elevator car. stevegbr attached the following image(s):
front and the rear part assembled. stevegbr attached the following image(s):
these parts are gear strips for the telescopic legs.
here is part 38, and parts. stevegbr attached the following image(s):
the canopy of the elevator car. stevegbr attached the following image(s):
elevator car three is now complete. stevegbr attached the following image(s):
here is part 39, and parts. stevegbr attached the following image(s):
the wheels and shafts are put together. stevegbr attached the following image(s):
here is part 40, stevegbr attached the following image(s):
this vehicle so far. stevegbr attached the following image(s):
the two gears are put in place from the previous part. stevegbr attached the following image(s):
the two small gears and shafts at the front are in place. stevegbr attached the following image(s):
and one gear and shaft at the rear. stevegbr attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,192 Points: 15,725 Location: ipswich
It's looking great - but what are the four long steel shafts protruding from the brass leg pieces?
Roy.
hi roy, the are like coil spring, which connect to the two white gear strips, when the motor is switched on they push the telescopic legs out and back in again.
here is part 41 and parts. stevegbr attached the following image(s):
