Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
those close up pics look bad but from normal eye distance it looks nice and tidy  cheers benny
 cheers benny
 cheers benny
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
Is this area not painted black???
colin..yes but was just testing..like i said..i will sand it again and paint it the appropriate colour..i wanted to see what the ochra looked like on the veneer cheers benny
Ah right, sorry benny for not reading it proper looks good thought .
cheers colin ill forgive you cheers benny
Also I think the doors open up/down rather than left and right.
John
z8000783 wrote:Also I think the doors open up/down rather than left and right.
John hi john i think your talking about the extra pieces of wood on the left and right of the ports...there the gallery supports that you can see on all builds that are as far along as mine and not door hinges,there supposed to be there  see pic  cheers benny
Of course sorry, it looked liked you were trying the doors out.
John
cool  those ports are only viewing windows, i think, and will be closed on the build with lids cheers benny
Hi benny! Looks like you fooled them with the gallery supports, fancy thinking they were doors.  With the test paint on you can still see the edge of the planks that’s good, I bet you’re glad!
yes darron i am, as you know the vic is 250 years old and planked so that was important for me to be able to see the lines.if its just smooth it will look odd.the first planking is glued on the edges as well as the back so when sanded you wil get a smooth flat finish..just my opinion...cheers paul cheers benny
hi all,i have started my veneer, its going ok now i have got the hang of it,bit of a shaky start..the veneer is 0.5x5mm walnut...i have learnt alot from doing this ie the dropper planks which i didnt do on the first planking cause i knew i was second planking  cheers benny
it needs a good sanding yet  cheers benny
 cheers benny
Very nice job Benny, keep up the good work. Cheers MWG MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
i have given it a good sanding to see how it looks  cheers benny
 cheers benny
 cheers benny
Guest (7)
