12 Pages «<34567>»
Gils HMS Victory - Cross Section Build Options
#81 Posted : 10 November 2016 21:16:09
#82 Posted : 11 November 2016 16:56:03
Hi Gil.
Really nice clean looking build. look forward to seeing more of this one.
Ian Cool Cool BigGrin
GilShapley
#83 Posted : 15 November 2016 11:31:20
Issue 133
Orlop Deck Finished and stained dark oak
I have decided to paint the bulwarks white as I seem to remember from my last visit to the Victory that this was the colour scheme. It makes sense because it must have been a dark place and any reflected light would be welcombe.
Holes cut in the deck, no major issues here but pay careful attention to step 2 and make sure you glue these planks along their edges.
The bulwarks will require another coat of white but this will be added once the rider tops and knees are in place.
Issue 134
Orlop pump well, Only thing I can say here is make sure you have the parts correctly orientated, it is easy to get them the wrong way round.
With the riders and knees I decided to replace those provided with ones I have make from some pine strips using the ply ones as templates. Went to the hobby shop for some 4mm wood and nearly died at the price of a small piece, so off to the DIY store and purchased a 3 metre length of 4mm X 12mm which will do the job nicely and plenty left over for other projects. I find this pine nice and easy to work. Will add a coat of white paint to these parts before gluing in place and then add a final coat to the bulwarks
Nice fiddly job coming up, Making the seaman's chests, looks like fun
Current Build:-
GilShapley
#84 Posted : 19 November 2016 14:18:52
Have now fitted the rider tops and knees and installed the orlop pump well
Final coat of white paint added where required.
As to what paint to use. I tried Admiralty Dull white but found this far to thin, it bled under the masking take tape and I had to rub down the deck and restain. In the end I bought a tester pot of white interior wall and ceiling paint £1.99 for 75 ml (admiralty paint is approx £2.00 for 18ml) I found this emulsion much thicker and no problem with bleeding, its dries nice and quick as well
Current Build:-
#85 Posted : 19 November 2016 16:50:31
BigGrin very nicely done Gil and a good tip on the paint looks good Cool
#86 Posted : 19 November 2016 20:17:14
Lovely job Gil BigGrin
#87 Posted : 19 November 2016 20:24:05
Very neat and tidy, looks superb!
#88 Posted : 19 November 2016 22:06:30
Looking great Gil... I found the same with Admiralty Dull White but persevered with it.... Blink Blink .. Great tip using a tester pot....Cool Cool
#89 Posted : 19 November 2016 22:07:51
Very impressive work as usual.
Well done. Cool Cool Cool
#90 Posted : 20 November 2016 01:15:51
Excellent work Gil. Look forward to seeing more.
#91 Posted : 20 November 2016 10:43:28
Very nice work Gill, I can see you are enjoying this build.
Trev.
#92 Posted : 21 November 2016 14:00:31
Very nice work Gill looking the business.
GilShapley
#93 Posted : 21 November 2016 20:23:54
The build has reached the stage where some of the "furniture" needs to be constructed, in this case the seaman's chests. This is one of those cut a bit, glue a bit, and wait jobs. I sometimes wonder if I spend more time waiting for the glue or paint to dry then actually modelling. I can understand why some of you have more than one build on the go (Mmmm thinks, can I convince SWMBO Naa)
I have made 7 so far and may make some more later but for now back to the main build.
Current Build:-
#94 Posted : 21 November 2016 20:29:17
Magnificent chests Gil. that sounds a bit rude!!
#95 Posted : 21 November 2016 20:30:11
Nice work on the chests, they look fantastic!BigGrin
#96 Posted : 21 November 2016 20:40:27
Drool lovely work Gil the chests look brilliant Cool
z8000783
#97 Posted : 21 November 2016 20:41:50
Groups: Unapproved
Beautiful work Gil.
#98 Posted : 22 November 2016 05:47:18
Hi Gil,
Great job on the chests.
Hans
#99 Posted : 29 November 2016 09:40:55
Beautiful work there Gil. Those chest look great.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#100 Posted : 29 November 2016 15:25:05
Hi Gil. the cases look fantastic well done.
Iam Cool BigGrin
12 Pages «<34567>»
This page was generated in 0.210 seconds.
