Hi Jinx Tomick can u advice please  pottering about on superstructure waiting for putty to dry When i offer the tower to the decks there is a big gap I notice on Tomicks build he has a base plate on the bottom of his towers this will obviously get rid or reduce my prob Appreciate that Tomick is not constructing his model in order of the instructions we download So checking Jinks diary (hes been good enough to put photos up of parts rx)but i cant see his base plate Did u rx one Jinks??? notice you filed & filled the parts in question Apoligise for hassle but wondering if i will rx part in later issue or is this another difference like frame #7/#8
Its not a problem, a tower base plate is supplied later in the series where the tower is then advised to be put in place.
Though if your keen to crack on you can make up your own baseplate to suit.
