Issue 84 Compromises Options
SimonC
#1 Posted : 28 October 2016 20:15:00
Rank: Amateur Level 1
I am doing the cornices - a very fiddly and repetitive task I must say. I find that I am making some compromises in step 9. In magazine photo it shows the beak with vertically arranged gold strips. Where the upper planking of the beak meets with the hull I do not have a vertical join - same with the left hand edge of this plank. In my photo you see that I have compromised a bit with this when positioning the gold painted strip. I will have to do the same with the left edge of the upper planking of the beak - it is nowhere near vertical. I suppose I could cut a bit off to make it more vertical.
My question is: how important is it to make these cornices appear vertical?
How do I attach this picture Cursing !!!
Copy of IMG_4774.JPG (1,151kb) downloaded 46 time(s).
SimonC attached the following image(s):
#2 Posted : 28 October 2016 23:43:36
Hi Simon, from what I can see I would say the problem is purely aesthetic, the gold upright strips should be vertical so I'd be trimming. As for your picture problem, for me I find the easiest method of uploading pics is to follow the information contained in the attached link.....
http://forum.model-space....aspx?g=posts&t=244
When posting photo's you should ensure you adhere to the requirements outlined within the forum rules....
http://forum.model-space....aspx?g=topics&f=49
Hope this helps..
This page was generated in 0.202 seconds.
