11 Pages «<56789>»
Time machine 2002 Options
#121 Posted : 24 October 2016 16:42:11
BigGrin Coming together nicely nowCool
#122 Posted : 24 October 2016 16:55:31
Really looking the part now. I didn't realise how big it was until I saw your hand in the picture, its huge!Blink BigGrin
#123 Posted : 24 October 2016 20:36:35
Very nice work on the replacement castings Carl, they look to be a great fit, well done. I too am surprised at just how big this model is. Huh Blink Cool
kpnuts
#124 Posted : 25 October 2016 20:29:11
Well I'm glad I stumbled onto this one, it's just incredible, what else can I say.
#125 Posted : 25 October 2016 22:28:03
Gets better and better everytime I look in, looks fab....Cool Cool Cool
Alan4
#126 Posted : 26 October 2016 14:29:43
Started work on the petals.The upper and lower parts of the time ring have 2 rows of petals.These are made of clear resin.There was a ton of flash on the clear resin and on the parts that hold the clear parts.So I have started cleanup and test fitting of the petals.All 36 of them Cursing Cursing
#127 Posted : 26 October 2016 15:29:48
More great work CarlDrool BigGrin thats the only problem with resin kits flashCrying but you`ll clean it up in no time mateyCool regards Phil
#128 Posted : 27 October 2016 16:23:59
The supports for the petal are now glued to the center wheel and out rim.This will get a final sanding and then off to paint.There is a second ring that sits on top of this one that I am working on next and then I have to repeat the whole procedure for the lower ring.
GilShapley
#129 Posted : 27 October 2016 16:41:51
I have sussed it. I know why you are building the time machine. Once completed you are going to use it to go back and tell yourself not to build the Jupiter
Seriously though this is one cracking build
I shall continue to watch the build progress with interest
Gil
Current Build:-
#130 Posted : 27 October 2016 16:42:52
That's looks not very nice Carl, the 3D printed parts look great Cool
#131 Posted : 27 October 2016 18:40:42
Really taking shape now and an interesting build, wel done so far Cool
#132 Posted : 28 October 2016 14:51:31
Thanks everyone,
interesting you talk about time Gil.When I ordered the kit a couple of years ago it went missing in the mail.It somehow ended up at Paypals headquarters. Paypal refused to send it back to the sender and said it has been destroyed .Randy sent me another kit.2 years later he received the original kit in the mail.Where it had been for 2 years is a mystery.Maybe it was stuck in a time warp!
Anyway the second wheel and row of petals has now been assembled and test fitted onto the first ring.next step is to paint everything and then attach the "glass" petals.These are made of clear resin.
#133 Posted : 28 October 2016 19:00:40
BigGrin Nice workCool
#134 Posted : 29 October 2016 14:52:43
Cheers Andy.
There is an actuator arm that attaches to each of the petals of the first ring.They are resin castings and have a pretty big pour stub.I am impressed by the molding, but getting them off the pour stub without damage proved very difficult.I was lucky to only break one out of the 18 actuators.
#135 Posted : 09 November 2016 13:23:07
Hi Carl.
Your time machine is looking fantastic. very detailed build. look forward to seeing your progress Ian Cool BigGrin
#136 Posted : 10 November 2016 15:32:18
Now I am test fitting one of the outer rings of petals.The petals are made up of a clear resin piece and the frame.of course the petals dont fit into the frames well so it has taken quite a bit of fettling to get them to fit.nest step is to do the second out ring and then repeat the process for the main ring of petals.There is still a ton of work to do here.Not sure if this will make the build competition deadline.
#137 Posted : 10 November 2016 21:22:02
It'll be a shame not to hit the deadline but understandable if it means carrying on with the high standard of work you've already put in to this Cool
#138 Posted : 11 November 2016 14:23:33
Cheers Dave,
I have now finished the outer rings with petals.The main rings are also done so now I have to make 18 petals to attach to the main rings and then the 2 rings on the left attach to the central ball and act as a base for the 2 rows of petals.
#139 Posted : 11 November 2016 15:55:03
Really is a pleasure to see you build this CarlBigGrin the detail is superbDrool as are your scratchbuilt modification`sCool Phil
#140 Posted : 14 November 2016 04:05:56
Thanks Phil,
the time rings are finished.there is a scale etched onto the rings.it was poorly defined on the resin parts so I sanded off the scale and used a decal made by a friend to make the scale.I also added copper tape around the edge of the ring.
11 Pages «<56789>»
This page was generated in 0.232 seconds.
