Uploading Pictures Options
Mo
#1 Posted : 23 October 2016 16:20:30
Can anyone help here, I am using a iMac, how can I get a picture from my photo library in to a post, I have tried dragging and dropping, but see my last post the picture does not appear.
Mo
Mo
xander
#2 Posted : 23 October 2016 16:49:54
Rank: Amateur Level 1
I have uploaded a few pictures on my build log using my MacBook Pro.
First I resize the picture to 600 pixels horizontally and save to desktop.
Then I attach it to my post and post it.
However I have found that the pictures sometimes don't appear on my build log and I have to keep reloading the page for them to appear. I don't know whether this is peculiar to Macs or my browser.
Xander
Mo
#3 Posted : 23 October 2016 17:11:23
Thanks for that.
I think its perhaps this forum needs updating.
I have just found my way back into my photo bucket album.
mo
Mo
Mo
#4 Posted : 23 October 2016 18:33:22
in my photo bucket album, I have the pictures,
In the box that shows the picture, in the bottom right hand corner there is a small box with a tick in it,
At the bottom of the picture, in a grey box there is a file No ending in .jpg
Below the picture there are 4 boxes marked E mail & IM, Direct, HTML, & IMG
How can I get the picture on the post, I have tried putting it in-between the mountain icon, [img]http://s1251.photobucket.com/user/mosurprise/media/file_zps9b1a16f6.jpg.html?sort=3&o=3/img]
This is what happens.
Help please,
Mo
Mo
Mustang
#5 Posted : 23 October 2016 19:14:38
I only use an iPad or MacBook.
I've not had any issue posting photos with either one.
I just use the IMG link.
I remove the first section starting with [URL........ Ending with jpg.html]
I only keep the section starting with [IMG : ....... and ends with the .jpg[/IMG section
And remove the [/URL] from the end.
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
#6 Posted : 23 October 2016 19:38:04
Hello Mo,
When you are in your photobucket album and selecting photos, just right click on the IMG code box. If your photos are in 'thumbnail' format then the code will be located below each photo and will turn blue when you click on it, then just select 'copy' from the drop-down menu then come back to the Mdelspace posting box, right click in the box where you want to put the code and select 'paste'. If you are looking at your photobucket photos in the 'enlarged' format (one photo on the page), you need to just left click on the IMG code box (which is usually to the right of the photo) and it will turn yellow and say "copied", then just come back to the Modelspace posting box and right click and paste where you want it. That should be job done.
You also need to make sure that your photo sizes are set at either 640 x 480 or 800 x 600 (I use the latter) for uploading?
Hope that helps?
Mustang
#7 Posted : 23 October 2016 19:47:48
I've set my camera to take photos at 1024 x 768, this size works well for me.
You can set PB up to change the size of your photos as you upload.
To build:-
#8 Posted : 23 October 2016 19:53:57
Mustang wrote:
.... You can set PB up to change the size of your photos as you upload.
Correct Ian. That is what I meant though I should have made it clear that I was referring to the upload size settings on Photobucket ready for loading to other sites. I wasn't referring to size settings on the camera or PC when uploading to Photobucket? Apologies for the lack of clarity.
A lot of people seem to struggle with Photobucket but I think it's fine once you understand how it works? On the downside, I have had some of my photos mysteriously disappear from my library without my consent or knowledge which was not very helpful!!
