4 Pages «<234
AgentRev's Build diary Options
#61 Posted : 20 October 2016 06:48:00
BigGrin Great stuff and congrats on your first print. I have had the same problem as yourself with the Pumkin print I did, print starting in different places a few times and slid sideways like yours in the print process.
I actually think its the downloaded code doing this and not the program were using as when you load it into the program it may get corrupted and you get the bad result but load it again and its ok.
Bit of a lottery at times but all part of the fun.Cool
#62 Posted : 20 October 2016 09:25:55
Congrat's on your first print, Mr Owl looks great Cool
AgentReverie
#63 Posted : 30 October 2016 22:07:56
Thanks everyone!
Carl, I fiddled around with the repetier host centering as you mentioned, and I believe that will help a lot.
I seem to be getting leakage around the nozzle assembly. I tried tightening the nozzle again, but it still has melted PLA leaking out. Anyone have this issue? Thanks
#64 Posted : 31 October 2016 01:24:56
Not had that issue.I think if I remember you had to tighten it when it was hot but I am not sure.Check the instructions.That may be your problem.
ps
Here is a link to the official build diary where Mr T talks about tightening the nozzle when it is hot
http://forum.us.model-sp...spx?g=posts&t=17252
#65 Posted : 03 November 2016 17:03:47
AgentRev,
did you fix your nozzle leaking. If not you can use heat proof threadlock to seal the thread an prevent leakage
AgentReverie
#66 Posted : 03 November 2016 23:50:31
Oh thanks, I will probably try that, as I already tried tightening it while hot.
AgentReverie
#67 Posted : 28 May 2017 20:45:38
Isn't the printer supposed to move to the center of the bed to begin printing?
Mine is not doing that. Does anyone know how I can adjust that?
Thanks
Edit: actually it looks as though it may be okay now. It just isn't in the exact center, so I'm not sure what the issue could be.
Fidget spinners seem to be the sudden rage here in the USA, so wish me luck. lol
4 Pages «<234
