Hi all, finally managed to finish issue 126 and this issue turned out to be a fairly long session, mainly due to working in confined or awkward areas. Space now to work in around the ship is starting to get very cramped and it is so easy to catch or break something if care is not taken, key here is to take your time and work gently. Started with the fitting of Main Royal Yard and Sail. Fitting and rigging this small sail on top of the main mast was pretty straight forward, except for when it came to attaching lines in and around the deck area. The Halyards were fitted, securing these to the yard and to cleats on the main deck. Next was the fitting of the lifts, again straight forward and securing these to the pin rack in front of the main mast. Fitting the sheets was next to be done including the fitting of blocks to the shrouds, would recommend these blocks are fitted prior to starting any of the rigging while you have the space to work in. The sheets were secured to belay pins on the bulwarks. Finally for this sail was the fitting of the braces, the braces run to the top of the mizzen mast and secured to belay pins on the quarterdeck bulwarks. Next on the list was to fit the foresail, this was done in much the same way. Started by securing the sail to the yard, making up the parrels and securing the yard to the foremast. Halfyards were secured to the bitt in front of the mast, again very fiddly due to lack of space. Sail rigging lines were fitted in the same way as the other sails. The braces are attached to the lower mainstay, these should be secured with a drop of CA. That concludes another issue and issue 127 gets underway… Will update again soon so until then happy modelling… Regards Alan Gandale attached the following image(s):
 Lovely work Alan looking at your pictures I had forgotten how little room there is around the deck  one small tip don't where a wrist watch as I nearly dragged my old girl off the table when a shroud got caught Happy building rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
An amazing job you are doing with this build, Alan. You have set the standard which we will all try to achieve with our own builds. Looking forwards to more updates. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Thanks Martyn, Stephen. Appreciate those kind words as always.... Regards Alan
That is a stunning bit of workmanship Alan, not much else I can say!
This would not look out of place in a museum.it is a truly remarkable model.
darbyvet wrote:This would not look out of place in a museum.it is a truly remarkable model.
Thanks Carl, very high praise indeed.... Very much appreciated.. Regards Alan
Superb job Alan, she certainly looks fantastic. Graeme
Alan A fantastic build diary and a beautiful model you have put together - it looks absolute perfection. Happy Modelling
 Rank: Amateur level 2     Groups: Registered
Joined: 09/07/2013 Posts: 41 Points: 123 Location: Alberton, South Africa
Hi Alan, I must admit I have been following you diary for quite some time and found it most enjoyable and it's helped me tremendously. Your ratlines are absolutely stunning  and when I get to that stage if mine are half as good as yours I'll be happy. Regards Steve Present Build: San Fransisco II, 1/32 Lancaster Bomber
Subscribed to: Sovereign of the Seas
Completed: La Toulonnaise, Harvey
Thanks everyone for looking in, very much appreciated..... Steve, those ratlines took an age with every knot hand tied... was almost brain dead by the time I finished but think the effort was well worth it..... Take your time with it, do it in stages and am sure yours will turn out great.....  .. Have been following your build too and think you're doing a fab job.... well done..... Regards Alan
Hi Alan. Looking Fantastic. I prefer the rat lines hand tied. look forward to seeing more Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 09/02/2012 Posts: 569 Points: 1,675 Location: Scotland
. Looking good as always.
Mo. Mo
Thanks guys for looking in, appreciated.... Regards Alan
Joined: 24/05/2015 Posts: 74 Points: 212 Location: Camberley .Surrey. UK
Having quite literally stumbled upon your build log some two years ago I have been an avid follower. The care and precision you have demonstrated in the building of this ship and the thoroughness of your build log for others to follow is outstanding. It is of no surprise to me you have been awarded the yellow medal for an outstanding model so a hearty congratulations Alan. I think your SOTS would be a worthy exhibit at any venue. I am sure that I'm not the only one who has been inspired by what you have achieved into starting a build of their own. Thank you so very much. Kindest regards Nige Building: Sovereign Of The Seas Reading About Everyone Elses Builds[/b]
Enjoy Making
Nige
Nige wrote:Having quite literally stumbled upon your build log some two years ago I have been an avid follower. The care and precision you have demonstrated in the building of this ship and the thoroughness of your build log for others to follow is outstanding.
Thank you very much for those very kind words Nige. The inspiration I get is down to people like yourself who have followed my build and its diary and from there have taken the plunge to try this build for themselves. Excellent results are possible for all through the simple process of taking their time and following the instructions as laid out. Once experience is gained then they can start to change and modify builds to their own personal taste... If I can motivate people to take on this remarkable hobby then my aim has been achieved and of course, I will assist wheneve I can...... Thanks again Nige, appreciate your comments very much.... Regards Alan
Joined: 29/12/2017 Posts: 3 Points: 9 Location: Ramsey, MN USA
Hello Gandale,
I am in the middle of gathering research info on building the DeAgostino Sovereign of the Seas. My early career was as a 2nd Engineering Officer on merchant ships, and tall ships have been a love of mine since I was a small boy. Seawater still flows through my veins. I'm saving the money to purchase this fine kit, which will be my first plank on frame model. The level of extra detail in your build is such an inspiration that I will endeavor to walk in your footsteps and use the same fine additions and details which you have made. All I can say to you is BRAVO! I truly appreciate your build because like yourself, I am a very detail oriented individual and building this ship model is the manifestation of a long held dream. Thanks you so much for providing the guidance that goes so far beyond the instruction booklets that it should be included in the box!
Best regards,
Kurt Suleski in Minnesota
DARIVS wrote:Hello Gandale,
Best regards,
Kurt Suleski in Minnesota Hi Kurt, I can only but thank you for those very kind comments and it pleases me no end to hear my build has given you some inspiration to purchase and construct this wonderful model. She is a challenging but absolute joy to build and with the detailed step by step instructions, together with the build diaries on this forum then I'm sure you'll enjoy the experience of building her one day. Remember too, I'll be hear to assist should you need it and I do hope you'll produce a build diary to let us follow your own progress..  .. Thanks again for the kind comments and good luck with your new venture...... Best regards Alan
