12 Pages <12345>»
Gils HMS Victory - Cross Section Build Options
#41 Posted : 13 October 2016 23:10:41
Excellent work Gil. Looking amazing. Drool Drool
GilShapley
#42 Posted : 16 October 2016 12:19:22
Issue 126 exterior planking now completed and sanded.
One thing I have noticed apart from the variation in colour of the planking,not a problem for me as I will be painting mine the same colour scheme as my Victory model, is that the planks do vary in thickness so some sorting was required.
Issue 127 next, The Mast, pump and shot lockers. I intend to replace the provided shot with some black cannon balls, not ssure how many I will need but they are readily available from CMB in various sizes
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
#43 Posted : 16 October 2016 13:19:47
looking very nice indeed.
hope the next phase of your build goes well.
#44 Posted : 16 October 2016 18:29:24
A great job Gil, nice clean build.
GilShapley
#45 Posted : 19 October 2016 14:41:17
Issue 128
Completing the hold planking
This was straight forward, just be careful to make sure the two notched planks are cut to mirror each other. Step number 4 refers
Fitting the riders. I decided to use a slightly different method here. Instead of making up two complete assemblies and then gluing them together to make one rider I glues the component pairs together then constructed the riders with these. Found this easier to handle and had no problems with lining up the sections.
Issue 129
Adding the false keel. Here I glued the two lengths of 1.5 X 8 mm together and when set attached them to the keel.
The stand I had already completed as I am using this to support the Cross Section during the build as I have made my own stand to display the finished model
Issue 130 next
Current Build:-
#46 Posted : 19 October 2016 15:34:14
Looking good Gil, very neat and tidy work.....Cool Cool
#47 Posted : 19 October 2016 15:42:27
Top notch woodworking as usual Gil
michael.rolph
#48 Posted : 19 October 2016 16:12:32
Great progress Gil
I've just ordered this kit, I'm planning on using it for next years build of the year
#49 Posted : 19 October 2016 17:20:49
Great update Gil, she's looking good Cool
#50 Posted : 20 October 2016 12:19:56
Hi Gil.
Great looking cross section.
Look forward to seeing your progress.
Ian Cool BigGrin
#51 Posted : 20 October 2016 12:40:18
The good thing about this kit is that its very informative of how the real hull was constructed as it closely follows the real thing.
Looking great, keep up the good work Cool
GilShapley
#52 Posted : 20 October 2016 13:39:41
Thanks for the feedback folks. In the interest of authenticity anyone know where I can get 1:72 scale ships rats to put in the lower deck?
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Current Build:-
#53 Posted : 20 October 2016 14:52:31
Very true.I have Corels HMS Victory cross section and the hull section is one solid piece Angry Angry Angry
#54 Posted : 24 October 2016 20:29:23
Hi Gill,
Your build is looking very good, bet you are enjoying this one.
Trev.
GilShapley
#55 Posted : 27 October 2016 15:26:58
Issue 130 - Cutting the chain pump opening, what can I say just make sure you align the port and starboard correctly as there is a difference in the alignment.
In this stage we complete the pump well, after stainingthe interior the outside of the well is planked with oak veneer. I decided it was easier to add the veneer before installing the well in the model, there is a lot of trimming and the veneer is thin and fragile, in fact I was able to trim the straight edges with a pair of sharp scissors and finish off with fine sand paper
Issue 131
I have opted for the open version of the shot locker and am waiting for some black steel cannon balls to arrive to complete this part. In addition I added some "bolts" to the hinged lids of the shot locker. Just a matter of using some of the pins I had left over from my Victory build, cut down to a few mil and after some careful drilling inserted into the hinge holes.
The pump well door was next. With the pump well still not in situ this was an easy addition.
The Hold Platforms come next. Some careful trimming required here to ensure a good fit against the hull. Once stained with the dark oak they can be installed. I added these platforms before the pump well as it gave me more room to work and I could ensure both platform where level.
The well was then added.
Just the orlop beams to add to complete issue 131. Waiting for the stain to dry
Current Build:-
#56 Posted : 27 October 2016 15:47:07
Beautiful woodworking as always Gil.
#57 Posted : 27 October 2016 17:01:52
Looking good Gil, great idea to cover the Pump well before installation.
#58 Posted : 27 October 2016 19:28:21
That`s good work, especially like the shot locker hinges.
Neat little addition.Cool Cool
Mo
#59 Posted : 27 October 2016 19:37:55
Good bit of work going on here.
Mo.
Mo
#60 Posted : 27 October 2016 19:59:23
BigGrin very nicely done Gil love the shot locker Cool
Guest (5)
12 Pages <12345>»
This page was generated in 0.257 seconds.
