Yo ho, a pirates life for me (Wicked Wench (proto Black Pearl), Hachette) (32/120) Options
greyhawk
#1 Posted : 16 October 2016 15:16:13
In 2003 Disney decided to turn one of its more storyless theme park attractions into a movie by stealing the story line of Curse of Monkey Island and telling Johnny Depp to go hogwild. The result was the Pirates of the Caribbean franchise, which singlehandedly made pirate movies cool again after Geena Davis killed the genre in 1995. One of the most unique parts of the movie was the fastest ship in the universe, the Millenium Falcon, wait, I mean Black Pearl. A burned out husk of a ship it was still able to do the Caribic Run in less than 12 parsec.
Several years later Disney cooperated with Amati to develop a model of one of their theme park ships, the Wicked Wench. Apocryphically the theme parks Wicked Wench IS the movies Black Pearl before it went up in flames.
Coinciding with the release of the fourth PotC movie, Disney, Hachette and Amati decided to publish a part work version of the Wicked Wench model, which while unchanged they decided to simply call the Black Pearl nonetheless. This introductory ship model is mostly aimed at teens and young adults, so building it is in parts much easier than your usual part work fare.
I need something to do between deliveries of the Soleil Royal and can't be bothered to deal with my more serious ship builds right now, so I de-iced this partwork from the basement.
This will be a pure oob build with no amendments, improvements or even thinking about historical inaccuracies with this fantasy ship. The idea is to build the kit with my brain turned off while watching pirate movies for instance.
This build will be the half-open version with full interior.
The kit loves its gimmicks. By issue 2 we have spent more time on buildling a presentation stand for the Jolly Roger and figure head than on building the ship itself. I think that's a rather nifty idea. Zoukei Mura do something similar with the engines of the Horten 229 model.
Here we see the rather unique way the keel is built. Arriving in three segments frames are already installed in each segment even when they are not joined together yet.
This is not a problem though. A rather hefty system of support beams ensures the frames will end up in the correct positition no matter what.
By issue 7 a stand already arrives. I love this. It is also highly dangerous if you're going to do your own improvements. I have seen people spend months on kitting out this rather plain stand, then burn out and never finishing the ship.
The lower deck planking is actually a drawing on a piece of cardboard. While this may seem cheap at first, it actually looks pretty nifty once in place. When the side walls and middle decks are up I suspect one won't even notice.
You'll also note the first color has gone up. There's lots and lots of painting to do in this kit. Sacks and boxes of food, rum bottles, racks, cages in the brig, lanterns etc etc. You name it, you paint it. Which is fine by me, because I need to get better at painting.
#2 Posted : 16 October 2016 15:36:57
I've seen one of these finished and they don't look half bad. Does it give you much info with regards to painting or just basic instructions
greyhawk
#3 Posted : 16 October 2016 15:48:53
They go absurdly in-depth down to specific advice which colour to use from which manufacturer. "Better spraypaint these", "Here you're better of using acrylics" "Do these with enamel" "Now thin your humbrol 119 and bring out some highlights" "Now go drybrush these. Here's how you drybrush." "rub down a pencil on some sandpaper, pick up the graphite with a cosmetic brush and apply"
I absolutely love it. It's model painting 101.
#4 Posted : 16 October 2016 15:54:49
Sounds like an enjoyable time to be had with this one.
Will be interested to see your thoughts as the build progresses.
#5 Posted : 16 October 2016 16:02:13
For a better paint finish, you should use an MDF sealer.
If I recall rightly, it also comes with pre-painted crew figures.
Look forward to seeing how you get on Cool
#6 Posted : 16 October 2016 16:15:43
BigGrin Looking forward to seeing this come together Cool
greyhawk
#7 Posted : 16 October 2016 16:27:14
Yup, and they actually look good at least as far as I've seen.
Thanks for the tip. :)
The paint actually looks much better without the flash (also far less red).
My first thought was actually staining it but the surface of the MDF is so smooth and tightly packed, the stain doesn't even penetrate. One can simply take it off with a cloth even after minutes and it's like it wasn't even there.
On the other hand some irregularities add to the overall charm of the model.
With the cell walls for the brig I've even gone out of my way to slap on the colour as thick, sloppy and uneven as possible to give it a more cast iron-y look. (needs some drybrushing still)
daffy09
#8 Posted : 16 October 2016 16:29:45
It sounds like this one is worth doing just for the painting instructions. I've always been really scared of painting and always have endless worry about whether I'm going to ruin an otherwise great kit by applying either the 'wrong' paint, or applying it incorrectly. Looks like it's going to be a great build, and I'll definitely follow this one.
Happy building
David
#9 Posted : 16 October 2016 16:54:49
In that case instead of using a wood dye, you could try a wood stain which is painted on in a Matt finish.
greyhawk
#10 Posted : 24 October 2016 11:27:35
Starting with issue 11 the lower deck is outfitted. This includes the brig..
...door fittings and lanterns...
and a little rack for wine and rum and other essential pirate drink.
greyhawk
#11 Posted : 06 November 2016 23:20:38
One very nice thing about this kit is how much stuff they give you for interior decorating.
In the last 3 issues we got provisions and rum and barrels and ropes and all kinds of other fun stuff.
greyhawk
#12 Posted : 10 November 2016 10:36:17
#13 Posted : 10 November 2016 21:20:21
Looking very nice Cool I'm wondering if a wash would help bring out something me detail on the potatos Cool
greyhawk
#14 Posted : 10 November 2016 22:55:36
Probably, on the other hand things are about to get so dark below decks there's really no benefit to getting too detailed with these
Case in point:
Everything stowed away
The deck in place
#15 Posted : 10 November 2016 23:34:40
Very nice work.... this is a kit I do like the look of and with the open interior there is so much freedom and scope to model additional detail and items....Cool Cool .. Look forward to your next update....
#16 Posted : 11 November 2016 09:57:11
Great job with this. I do like the open interior, it gives an insight on how cramped the space was on these types of vessel.
greyhawk
#17 Posted : 21 November 2016 00:31:15
The thing one has to remember is that this is a glorified phantasy version of how things were below decks. The reality was much much worse.
Added deck beams and supports for the battery deck. Going to play architect for a while now while walls, doors and "windows" are added.
greyhawk
#18 Posted : 01 December 2016 17:11:45
greyhawk
#19 Posted : 09 December 2016 01:11:50
greyhawk
#20 Posted : 16 December 2016 10:06:43
Installed a bunch of tiny lanterns
and the stern gallery supports
After making some gratings (first one pictured here while drying, my first attempt with enamels) we will finally start with the planking.
This page was generated in 0.303 seconds.
