Metal parts Options
Ninja-Bear
#1 Posted : 15 December 2010 05:55:56
Am looking for a more efficient way of rubbing down the metal parts. Had thought about using a small wire brush attachment in a Dremel, has anyone tried this, or similar, and does it work ?
#2 Posted : 15 December 2010 15:31:30
You could try it, though most tend to use emery paper, though be mindful that the brush is not to stiff/hard a metal so as not leave deep surface scratches or that any fine detail is worn away.
Ninja-Bear
#3 Posted : 15 December 2010 20:59:07
Thanks for that Tomick, another question though. Having joined the two halves of the bridge recently how do I get rid of the join lines ? There is no gap to fill really so what can be done ?
#4 Posted : 15 December 2010 22:28:44
There will be a fineline joint gap, use a needlefile smooth the joint then apply filler and sand smooth.
Ninja-Bear
#5 Posted : 16 December 2010 07:51:16
Thanks again Tomick, that poses another question LOL I have been told by some people that PVA glue mixed with sawdust is ok to use as filler, instead of quick drying glue such as epoxy resin. What do you recommend to use ?
#6 Posted : 16 December 2010 09:29:37
Sawdust mixed with PVA as a filler for wood can be used, but its down to personal preference as to what you might use, there are lots of commercial model filler products available depending on what material you are filling.
I'm not quite sure what you mean in saying 'instead of quick drying glue such as epoxy resin'?
You should use glue's best suited for each task, I used aliphatic resin for the wood build, epoxy for the major metal castings and superlue (Cyano) for the rest.
Ninja-Bear
#7 Posted : 16 December 2010 10:03:34
I was meaning for filling in metal parts Tomick
#8 Posted : 16 December 2010 10:47:33
In which case I would not use sawdust mixed with PVA, for metal I use 'Squadron white putty' which is great for fineline filling and is fast drying/sands easily.
Can be found here http://www.netmerchants....dellers_white_putty_65g
Ninja-Bear
#9 Posted : 16 December 2010 16:06:23
Thanks Tomick, what I got from the shop was MMD green fast drying putty, will that do ?
#10 Posted : 16 December 2010 16:49:29
Should be ok
This page was generated in 0.109 seconds.
