 like the use of a drop plank very tidy looks the bees knees
Cheers guys...
Here is latest update on the planking..
Chris..magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Hi Magpie see u have zoomed in on the last picture Hope you don't mind me saying but my attention kept getting drawn to the earlier drop plank First thoughts were "what happened there" being a "big fan" of your build diaries & knowing your high standards and meticulous eye for detail i had a harder look and realise its not the shape or fitting of the drop plank but the colour of the drop plank that was drawing my attention to it Seems to be a lighter shade than the 2 planks joining it (maybe just flash off the camera) I take it it will blend in with a light sand & varnish??
Hi Budgie, yes it is slightly lighter m8, It was a 10mm walnut plank because i had glued the other two planks and they came too 6mm so had to use a 10mm planed to 6mm, I will see how it looks with a bit of wet on it.. Thanks Chris.. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Thanks for your reply Chris wasn't sure whether i should air my opinions incase interpreted the wrong way  makes a change from super,great,fantastic,stunning etc Keep up the the great work as am using u as an official build diary along with Hudson Robert (who is doing a grand job also but a wee bit quieter) Hope yous don't mind
Hi All,
Not much progress yet... just matching the planking from my previous pics on the other side of the ship...
Chris..On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Wow planking is really slow... Here are the latest pics I've done..
Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi All,
I have a small update on my planking. Its coming along nicely .. I thinks..
Chris.. magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi All,
Here is the latest of my updated pictures. I have now gotten near to the last planks. Only 12 more to lay ..
Hi All, Cheers Jack
I've managed to complete one side with just 6 planks on the other side. I have given the front a light sanding over to check all is well.
Here are the upto date picks.
Chris...magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Absolutely BEAUTIFUL job on the hull planking. Congrats!
Nice work MP
Hi All, Again..
Thanks Guys.. :)
I have now sanded the hull , my arms are very achy now...lol.. I have taken a few pics for you to have a look at. I can now finally turn her the right way .
chris...magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
That looks like really beautiful workmanship mate,,,keep the pictures coming... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi Chris That is awesome job mate... Mine Victory hull isn't anywhere near your standard :) All the best
Hi,
Thanks guys for your nice comments.
I have now installed the stern post and sanded smooth. Then proceeded to install the cabin. Then instructions are vague so just did it the way i wanted to and with pics of the prototype. I've only got as far as the last pics, may be going slower this week as I have 3 shifts at work then 1 day off then on for 4 Nights 11 til 8....YAWN.. I will be tired.. All for more money lol..
Joined: 12/02/2010 Posts: 44 Points: 108 Location: Oakdale, Blackwood, Gwent
Hi Chris, She's looking good, thanks for the advice on missing issue's, will see what admin comes back with first. Keep up the good work. Andre Building:
DeAgostini:
HMS Victory HMS Surprise Sovereign of the Seas H.M.S Victory Cross-Section
Absolutely brilliant magpie
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Thats a really stunning piece of work Magpie
