4 Pages <1234>
AgentRev's Build diary Options
AgentReverie
#41 Posted : 11 June 2016 21:42:05
Stage 20 to 25 more rod assemblies and fiddling about with getting the belts on them. Installing y-axis limit switch and slider belt clamps.
blurry sorry about that
Adjusting the belt/rod alignments...
Thanks for looking!
#42 Posted : 11 June 2016 23:40:52
Coming on nicely, WTG
AgentReverie
#43 Posted : 23 August 2016 23:47:21
Just got the email indicating to not use the power cable supplied with pack 10. Email indicates the supplied cable is the UK version (I'm in the USA). Do I recall correctly seeing something about this in someone else's build diary?
Anyway I guess my build is on hold for now, until the replacement arrives...
JC
AgentReverie
#44 Posted : 05 September 2016 17:46:41
I have received an additional e-mail, indicating to make sure US builds switch to 115V on the power supply.
Does anyone know if this is the solution to the issue or should I still wait for a new power cable?
#45 Posted : 05 September 2016 18:59:52
I am guessing that the cable issue is more to do with the style of the plug as i believe in the USA YOUR PLUG END DESIGNS ARE DIFFERENT TO THE 3 pin Uk version.
#46 Posted : 05 September 2016 19:43:06
Hi Rev
The power box has a standard switch to enable the use of the power supply in Europe and the USA to be utilized.
As for the power cable its got a UK 3 pin plug that is different to your plugs. The replacement will be the same type but with the correct plug to fit your power sockets.
AgentReverie
#47 Posted : 05 September 2016 21:35:25
Thanks very much. I'll just have to wait then, no worries.
#48 Posted : 06 September 2016 14:51:48
From what I understand the US spec power lead is being sent to US customers, approx 2-3 weeks.
Here it is if you can't wait..
https://www.amazon.com/C...mp;keywords=kettle+lead
AgentReverie
#49 Posted : 06 September 2016 22:17:20
I don't mind waiting, because replacement is included as part of the subscription ( I would think so anyway)
I was just a little confused as to which part customer service was emailing about, but I understand now.
Thanks
AgentReverie
#50 Posted : 11 October 2016 23:41:54
And so correct power cord has arrived. I hope to be able to print something this weekend.
#51 Posted : 12 October 2016 01:33:08
Excellent.I look forward to seeing some prints !!!
#52 Posted : 12 October 2016 07:47:40
BigGrin May your first print be a great oneDrool Love Cool
AgentReverie
#53 Posted : 16 October 2016 23:20:24
Finally finished up the build/calibration and tackled my first print today. Clearly I was very bad at updating my build every step of the way. But here you go...The first part of the print appears to have slid slightly? Or maybe it's a raft setting issue.
3D printing 10-16-2016 by JJ Cano, on Flickr
AgentReverie
#54 Posted : 17 October 2016 01:21:09
Stopped partway through. Don't know why. Overheating?
Taking a break, will try again some other day
#55 Posted : 17 October 2016 16:00:46
Great to see you got it finished and started printing Cool I can't help with why it stopped though
AgentReverie
#56 Posted : 18 October 2016 22:46:39
No worries. I am attempting again today!
Does anyone know if it is normal for it to start at the back like in the picture above? Wouldn't it be better in the middle of the table? Maybe I need to recalibrate or adjust something in the settings.
#57 Posted : 19 October 2016 01:26:52
That is a bit odd.You can center the object in repetier host to the center of the print bed.maybe try at different .stl file to print.Thingiverse has tons of free 3d models to print.
AgentReverie
#58 Posted : 19 October 2016 23:13:50
Here is my first successful print , a happy little owl, under an inch tall. Found at: http://www.thingiverse.com/bs3/designs
#59 Posted : 20 October 2016 01:29:26
Excellent.it looks great.It really is a nice little printer
#60 Posted : 20 October 2016 06:20:20
WTG, Cool Cool Cool
It`s working, well done for persisting and a cute first print. Love
Apologies, as it seems you have not been awarded your Blue medal. So I will award it with your Red completion medal. Congrtas.
4 Pages <1234>
