 Hi ant hope you are having a great holiday  I glue my masts with good old PVA as it is easy to clean up if you get it on the decks  hope this helps rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
I printed some heads to use to replace the figurehead figure.here they are .let me know if you want them and I will send them to you. Carl darbyvet attached the following image(s):
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 04/04/2013 Posts: 89 Points: 270 Location: Stroud, Gloucestershire
Thankyou Carl they look Brilliant I've posted a PM Hi All just arrived at forest of Dean, how lovely is this place and accommodation not to bad either! The old adage "You cant take it with you"  . Heres a few pic cannons now done going to do some touchcing up and then set the lower masts for shrouds . Not going to go too mad on it this week due to several family visitors but will do a bit - gotta say thanks once again to the people who have been so kind (you know who you are) Ant antswain attached the following image(s): Current builds :
AL's HMS Surprise Model Shipyards HM Cutter Mermaid
Looks like a beautiful place to sit, relax and do some modelling..... Hope the sun shines for you Ant..... Regards Alan
Used PVA glue Chris to help set the ropes down for the cannon good tip you gave me some time ago - picture of Sister (Nurse Sharon) as I call her shes been Brilliant. Cheers all updates to come ..... Ant Current builds :
Thankyou Alan Youve always watched out for me on here and posted it is very much appreciated - it will be a good week. Ill have a look at your entries m8 Ant Current builds :
Ooooh it looks beautiful there, should be nice and relaxing for doing some building. I wonder if you could do any whitest in the hot tub
Reckon the ship might fall to bits so no not doing any in the hot tub  - not going to do much this week -because of too many family distractions but on with her next week - I wil post updates later. cheers Ant Current builds :
 Just relax and go with the flow ant looking forward to seeing your your update when you get home Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Just a bit of touching up - taken by Sister I had no idea you know when your in that concentration mode! cheers Ant antswain attached the following image(s): Current builds :
The holidays nearly finished and we've managed to get all the shroud ropes amd some of the running rigging made - just to serve and fit the lower shrouds now been feeling ok and had a good time but it will be good to get back home. A few pics cheers to all Ant Current builds :
The holidays nearly finished and we've managed to get all the shroud ropes amd some of the running rigging made - just to serve and fit the lower shrouds now been feeling ok and had a good time but it will be good to get back home. A few pics cheers to all Ant antswain attached the following image(s): Current builds :
Dont know what happened there ? heres the others antswain attached the following image(s): Current builds :
 Nice update Ant I have a ropewalk but haven't used it yet have you found it easy to use Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Excellent update Ant, certainly looks as if you managed to get quite a bit done....  .. Looking fab.... Regards Alan
It took a bit of head scratching and a lot of help from Johncal (fair play to him) but i seem to be making decent ropes each time now - hes right you need to attach a drill because you will be there for hours making one rope. But i have not yet found the need to rebuild it out of plastic and i am using 5 strand ropes on the shrouds. - that i think depends on personal preference of what fits your model. If you need any help set it up and get in touch - im more than willing to help if you want to pm me it might be easier to go through it by phone no probs m8. all the best Ant Current builds :
Thanks Alan much appreciated. Ant Current builds :
Hi Ant. Rigging of carriage tackle: URL=http://www.hostingpics.net/viewer.php?id=281880img058.jpg]  [/URL] Sorry,it's in French. crochet = hook muraille = bulwark affût = carriage. Right: fastening of rope around the single block. Now, fasten the fall of the tackle (4) between the two blocks as follows:  Otherwise the gun could move and could be very dangerous for the sailors.
Thankyou Alain I Have fully rigged the underdeck cannon but this is more about time constraints if you read the earlier posts you will understand. If i get the time i will do this as it is very useful information. Thankyou once again Cheers Ant Current builds :
Guest (10)
