8 Pages «<45678>
Graham's CB750 Build Options
bugsec
#101 Posted : 01 October 2016 15:00:32
Pack 19 contains Stages 60 - 62
Stage 60 - The base frame
Parts supplied: Base frame 8, Posts x 4, Oil tank sticker, Shims and Screws
Also required: Base frame parts from Stages 52, 54, 55, 56, 57, 58 and 59.
Got a bit over zealous and built the base forgetting to take any pictures so as it's similar to that of the Suzuki Hayabusa although slightly smaller I've cheated a bit and used the same set of pictures.Blushing
bugsec attached the following image(s):
bugsec
#102 Posted : 01 October 2016 23:07:08
Stage 61 - The rear suspension
Parts supplied: Kick-starter pedal rubber and Lifting handle.
Also required: Main frame assembly (Stage 59), Swingarm assembly (Stage 57), Shock absorbers (Stage 31), Threded pins (Stages 22 and 23), Chain cover (Stage 57), Pivot shaft (Stage 57), Nut (Stage 57), Washers (Stages 32 and 49) and Screws (Stages 22, 23 and 57).
bugsec
#103 Posted : 01 October 2016 23:08:36
Stage 62 - The display base speaker
Parts supplied: Speaker
Also required: Display base frame (Stage 60), Posts (Stage 60) and Screws (Stage 60).
#104 Posted : 01 October 2016 23:37:28
Great progress Graham, at this rate you will soon have it finished BigGrin
bugsec
#105 Posted : 02 October 2016 17:44:59
Thanks Al. Hoping to finish over the next couple of weeks but with her indoors wanting to decorate Crying I'll need ta wait and see.
bugsec
#106 Posted : 02 October 2016 17:46:04
Pack 20 contains Stages 63 - 65
Stage 63 - The control box
Parts supplied: Control box
Nothing to build with this stage.
bugsec
#107 Posted : 02 October 2016 17:46:53
Stage 64 - The control panel
Parts supplied: Control panel, Cable 47A, Cable 47B x 2 and Cable 52A
Also required: Ignition key (Stage 16) and Main frame (Stage 61).
I have already repaired the cables that are replaced here so have decided for the moment any way to leave well alone.
bugsec
#108 Posted : 02 October 2016 17:47:55
Stage 65 - The display base controls.
Parts supplied: Control panel cover, Control panel holder, Volume control knob and Screws.
Also required: Dispaly base (Stage 62), Control box (Stage 63), Control panel (Stage 64) and Screws (Stage 60).
#109 Posted : 02 October 2016 20:26:25
Nice work graham, she's coming along beautifully....Drool Drool
bugsec
#110 Posted : 04 January 2017 22:57:14
Pack 21 contains Stages 66 - 69
Stage 66 - The battery cover.
Parts supplied: Fuel tank base, Battery cover, Left side badge and Screws
Also required: Fuel tank (Stage 1), Control board (Stage 59), Main frame (Stage 64) and Screws (Stage 59).
bugsec
#111 Posted : 04 January 2017 22:59:02
Stage 67 - The oil tank
Parts supplied: Oil tank cover, Oil tank A, Oil tank B, Oil tank cap, Right side badge and Screwa
Also required: Mail frame (Stage 66) and Oil tank sticker (Stage 60).
bugsec
#112 Posted : 04 January 2017 23:00:23
Stage 68 - The fuel tank cap
Parts supplied: Fuel tank cap, Fuel tank cap holder, Fuel tank cap check, Fuel tank cap pin and Screws
Also required: Main frame (Stage 67)
bugsec
#113 Posted : 04 January 2017 23:01:16
Stage 69 - The left handlebar end
Parts supplied: Left handlebar end, Grip, Grip plug and Screws
bugsec
#114 Posted : 04 January 2017 23:47:48
Pack 22 contains Stages 70 - 72
Stage 70 - The front brake lever
Parts supplied: Front brake lever assembly, Front brake lever clamp and Screws
Also required: Front fork assembly (Stage 10)
bugsec
#115 Posted : 04 January 2017 23:48:48
Stage 71 - The oil hose and twistgrip
Parts supplied: Right handle bar end, Oil hose, Grip plug, Twistgrip and Screws
Also required: Main frame (Stage 68), Left handlebar end assembly (Stage 69) and Front fork assembly (Stage 70)
bugsec
#116 Posted : 04 January 2017 23:51:28
Stage 72 - Fitting the front fork assembly
Parts supplied: Speedometer cable, Steering stem and nut, Brake hose and Black adhesive tape
Also required: Main frame (Stage 71) and Front fork assembly (Stage 71)
stevegbr
#117 Posted : 04 January 2017 23:51:50
that looks fantastic, it really stands out.BigGrin
#118 Posted : 05 January 2017 13:58:58
Looking great Graham ThumpUp on the home straight now.
bugsec
#119 Posted : 05 January 2017 20:20:24
Thanks guys
bugsec
#120 Posted : 05 January 2017 20:25:20
Pack 23 contains Stages 73 - 76
Stage 73 - Test the electronics, fit the side stand and footrests
Parts supplied: Side stand pivot, Side stand, Side stand spring, Footrest rubbers x 2, Footrests x 2 and Screws
8 Pages «<45678>
This page was generated in 0.431 seconds.
