8 Pages «<34567>»
Graham's CB750 Build Options
bugsec
#81 Posted : 24 January 2016 21:31:33
Stage 53 - The LED tester.
Parts supplied: LED tester.
Also required: Front fork (Stage 10), Rear fender (Stage 35), Left frame half (Stage 21), Right frame half (Stage 52), Battery box (Stage 52) and AAA batteries x 3.
No building at this stage just testing LEDs and switches - Instrument panel, Indicators, Headlight, Rear left indicator, Rear right indicator, Tail light, Rear brake pedal, Kick-starter and Ignition switch.
bugsec attached the following image(s):
#82 Posted : 24 January 2016 22:33:40
That looks like some great fun.
Stunning looking model.
#83 Posted : 24 January 2016 22:59:45
Looking good ThumpUp I really like the look of the lighting on this Cool
bugsec
#84 Posted : 24 January 2016 23:05:39
Thanks for looking in guys.
Definitely enjoying this build.
#85 Posted : 24 January 2016 23:23:29
Certainly looks good with all of the lights on Graham and a lovely neat build too, you should be very proud of what you've achieved so far with your build - well done!! Cool ThumpUp
bugsec
#86 Posted : 25 January 2016 00:15:59
Thanks Kev much appreciated
Graham
#87 Posted : 25 January 2016 22:22:36
BigGrin Starting to look the part now with all the parts going together, nice workCool
bugsec
#88 Posted : 30 January 2016 19:38:19
Thanks Andy
#89 Posted : 30 January 2016 19:50:33
Looks fantastic, tempted by this once the Busa is finished!!BigGrin
#90 Posted : 30 January 2016 20:49:35
BigGrin When the lights get tested your getting near the end and nice workCool
bugsec
#91 Posted : 30 September 2016 22:48:21
Well after a short break if 8 months can be classified as short I've picked up where I left off in January.
Pack 17 contains Stages 54 - 56
Stage 54 - The drive sprocket.
Parts supplied: Base frame 5, Joint E, Carburettor tubes x 4, Drive sprocket and Screws.
Also required: Drive chain (Stage 30), Rear fork (Stage 33), Fork pivot shaft (Stage 33), Metal nut (Stage 33), Main stand (Stage 37), IR sensor window (Stage 39), Wire cables (Stage 40), Transmission case cover (Stage 45), Left frame half (Stage 51), Right frame half assembly (Stage 52) and Screw (Stage 45).
bugsec
#92 Posted : 30 September 2016 22:50:19
Stage 55 - The battery box cover
Parts supplied: Battery box cover, Base frame 3, Joint C and Screws.
Also required: Frame assembly (Stage 54).
bugsec
#93 Posted : 30 September 2016 22:51:23
Stage 56 - The rear fender sticker and the base frame.
Parts supplied: Base frame 7, Base frame 9, Joint D, Threaded knobs x 2, Rear fender sticker and Screws.
Also required: Rear fender.
bugsec
#94 Posted : 30 September 2016 22:52:03
Pack 18 contains Stages 57 - 59
Stage 57 - The rear fender and battery box
Parts supplied: Rear frame joint, Exhaust joints x 4, Joint B, Joint E, Base frame 2 and Screws.
Also required: Main frame assembly (Stage 55), Rear fender (Stage 56), Battery box (Stage 53), Wire holders (Stage 34) and Screws (Stages 32, 34 and 50).
Strangely at this stage you take apart the frame and rear fork that was put together at Stage 54.
bugsec
#95 Posted : 30 September 2016 22:53:26
Stage 58 - The centre stand
Parts supplied: Dynamo cover, Base frame 6, Joint E and Screws
Also required: Main frame assembly (Stage 57), Battery box cover (Stage 57) and Screw (Stage 37).
And at this stage we start putting the frame back together again.
bugsec
#96 Posted : 30 September 2016 22:54:28
Stage 59 - The exhausts
Parts supplied: Base frame 4, Control board, Joint C and Screws.
Also required: Left exhaust assembly (Stage 17), Right exhaust assembly (Stage 21), Exhaust pipe joints (Stage 57), Main frame assembly (Stage 58) and Screws (Stage 49).
#97 Posted : 30 September 2016 23:28:15
Very nice work, she's looking superb....Drool Drool
#98 Posted : 30 September 2016 23:28:26
Great to see you back with the build, looking good Cool
#99 Posted : 01 October 2016 02:50:25
Looking good bugsec and great pictures too ThumpUp
bugsec
#100 Posted : 01 October 2016 14:57:59
Thanks guys comments much appreciated.
Graham
8 Pages «<34567>»
This page was generated in 0.227 seconds.
