 Rank: Beginner Level 1 Groups: Registered
Joined: 22/09/2015 Posts: 6 Points: 1 Location: cheshire uk
Hi, Anyone know the best way and paint to use for the lettering on the tyres? I have tried a few and it never seems to d00ry..... Chemical reaction?
eBay has a few options for white tyre paint, though likely way too much qty for what you need
Correction fluid (Tipp-ex) works on some tires.I would do a test first to be sure it works on your tires.
Joined: 22/03/2016 Posts: 175 Points: 552 Location: Merseyside
As above I would (others on here have) use correction fluid. I plan on (after the build) doing the same on my Mustang tyres. Ive used it before on other models and it took well but defo do a small test first Steve Built- Shelby Mustang, Lamborghini Huracan Building-Spitfire, Redbull racing RB7, 3d printer, Honda CB750, Stage coach and Revell 1/400 Titanic
I use Tamiya white, never had a problem. I will be using masks and spraying mine when I start my MP4/4 build.
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
Nemesis wrote:I use Tamiya white, never had a problem. I will be using masks and spraying mine when I start my MP4/4 build. You actually mask off raised letters? DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
Metal Mech wrote:Nemesis wrote:I use Tamiya white, never had a problem. I will be using masks and spraying mine when I start my MP4/4 build. You actually mask off raised letters? The tyres on the MP4/4 are flat and I have masks for the goodyear lettering. On raised lettering I thin the paint and let it flow in the letters. I suppose you could mask them if you wanted too.
