3 Pages 123>
Sultan Arab Dhow Options
xander
#1 Posted : 21 September 2016 20:39:14
Rank: Amateur Level 1
I have started to build this model following some builds that are already in progress.
I have finished the first planking, and following their advice, am doing the deck planking next.
As a beginner I will be making many mistakes but am happy to get constructive criticism.
I will try and do a build log and hopefully work out how to insert some photographs.
#2 Posted : 21 September 2016 22:30:57
#3 Posted : 21 September 2016 23:10:22
Looks like you're doing a very nice job there Xander and I look forward to seeing more....Cool Cool
This link may help you get round the posting of pics issue.....
http://forum.model-space....aspx?g=posts&t=244
Hope it helps..
xander
#4 Posted : 22 September 2016 08:43:57
thanks for the advice.
Trying to work out how to update photos.
xander attached the following image(s):
xander
#5 Posted : 22 September 2016 08:48:30
Yes!!
seems to have worked.
Will post more when some progress has been made.
eebygum
#6 Posted : 22 September 2016 09:33:29
looking good
Terry
daffy09
#7 Posted : 22 September 2016 12:02:03
Wecome aboard xander.
Looks like you're progressing well with the Dhow. There are several completed build diaries for your build on here which may prove helpful, and the guys here are a great bunch and always there to answer any questions you may have as you progress, and I look for to seeing this one come together. Well done.
Happy building
Daffy09
xander
#8 Posted : 22 September 2016 19:38:24
Thanks for your advice and for your build log which I have found very useful.
Thanks also to Alan for help with posting photographs.
Xander
#9 Posted : 22 September 2016 20:19:10
Looks very neat so far Xander.Keep those pictures coming as you continue the build
#10 Posted : 22 September 2016 21:00:31
BigGrin I have this kit in my stash there are several build diarys on here although some are better than others. So i would advise looking at them all and choosing the one that helps you most or just use all of them for referenceLaugh Cool
#11 Posted : 22 September 2016 22:57:18
Its a cracking little kit enjoy
#12 Posted : 22 September 2016 22:57:50
A warm welcome Xander, your doing a great job building this boat. Hopefully your enjoying building her.
Look forward to seeing your progress. Chris
#13 Posted : 23 September 2016 00:50:14
Welcome to the forum Xander BigGrin
Hope you enjoy building the Sultan and keep the updates coming.
#14 Posted : 23 September 2016 15:13:15
Looking a very nice build look forward to seeing your progress ian.Cool BigGrin
xander
#15 Posted : 27 September 2016 19:30:24
thanks for your kind comments.
i have now planked the deck and having looked at other build logs have done this before the hull's second planking.
When the hull is finally planked the instructions say to sand it and then varnish.
Would it be better to give it a coat of tung oil before varnishing and how many coats of varnish should be applied?
Thanks for your help
Xander
#16 Posted : 27 September 2016 19:47:20
Looking very neat.
WTG
Cool Cool Cool
#17 Posted : 27 September 2016 20:32:04
Oil and varnish does not sound like a good mix to me.
Oil can help to bring out the colour of some woods but on some plain types you will not see much difference. Oil tends to work well on harder woods such as walnut.
Varnish again can enhance the finish of wood and is designed to dry evenly which with oil can be more difficult (just think about artists with oil paints versus acrylics).
Trying to varnish over oil could cause you some issues if the oil has not dried out long and well. The varnish if it drys could seal in moisture that will cause problems later on.
The other point to think about is that most glues will work on a varnished finish but mot always as well on an oiled finish.
My advice would be to go for one or other but not both.
xander
#18 Posted : 27 September 2016 20:36:12
Thanks Tony
I will stick to using varnish only.
Xander
xander
#19 Posted : 04 October 2016 21:17:19
just to update my progress.
Have now put a second planking on the hull.
Have also fitted the side gunwale covers so far only on one side of the hull. Then read further on they have to be stained and so I stained them with Tamiya Nato Brown stain.I think it would have been better if they had been stained prior to fitting them and that is what I am going to do on the other side of the hull.
Like Alan I too found the 1.5 x 3 mm walnut battens too narrow for the gunwale covers on the bow and stern and so i purchased some 1.5 x 4mm battens. However every time i tried to shape them the walnut kept splitting along its length and after many failed attempts i gave up. Instead i fitted the gunwale covers in sections which is not ideal but it was the only method i could find. I will try again when i do the other side of the hull but am not optimistic of any improvement.
A couple of pictures to show what I've done.
#20 Posted : 04 October 2016 21:33:12
BigGrin Very nicely done xander brilliant job Cool
3 Pages 123>
