Garboard Plank Options
Allan
#1 Posted : 04 December 2010 08:32:25
Hi How far up the Bow does the Garboard plank go as i cant quite see from Tomick's buildConfused ?
Allan
Zeptrader
#2 Posted : 04 December 2010 09:42:52
read this from tomicks build diary -
Quote:
Forward garboard plank - The bow plank should run straight on from the centre plank, and is twisted to fit the false keel and fillets between frames 13 and 14.
Do not bend the plank to follow the curve of the keel, but allow it to run straight on.
have a look at his picture and you can see its around frame 13 and 14, which is about right.
BigGrin
Zeptrader
#3 Posted : 04 December 2010 09:49:54
Again taken from the brilliant MSW tutorial which can be read here..
http://modelshipworld.com/phpBB2/hptintro.php
When fitting the garboard plank DO NOT allow it to curve up the stem piece as in figure 15A inset, keep it flat and straight. This is important, if allowed to curve up this will cause crowding of the following planks to the extent that numerous drop planks will need to be fitted. Drop planks are dealt with under their own separate heading later in this project.
Best advice is to keep test fitting and take your time.
Allan
#4 Posted : 04 December 2010 10:14:25
Nice oneBigGrin thanks for that as that explains it in greater detailBigGrin
Allan
#5 Posted : 04 December 2010 11:07:05
Noted in my diary ...."Forward garboard plank - The bow plank should run straight on from the centre plank, and is twisted to fit the false keel and fillets between frames 13 and 14."
Allan
#6 Posted : 05 December 2010 07:38:52
thanks i got all that bitBigGrin it was the terminating shape at the bow end i was confused aboutConfused and where to cut the surplus plank off but i think now the plank is cut on the false keel side of the plankBlushing
Thanks all
Allan
#7 Posted : 05 December 2010 10:45:58
Might be best you wait until you get hold of issue 36 which has lots of step-by-step photos of the process.
