Opinions wanted please Options
Metal Mech
#1 Posted : 16 September 2016 04:46:38
Ok so I want your guys opinion. My intake manifold has a paint scuff on it. Its small and I have a feeling it won't be noticed much once everything is built. Do you think I should contact customer service and ask for a new one or just go with the one I have? I posted a photo below so you can see what I am talking about.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
#2 Posted : 16 September 2016 10:36:39
Right here goes!LOL In my opinion it is meant to be aluminium and it has a very metallic finish, so if it was me I would re paint it flat aluminium.BigGrin
#3 Posted : 16 September 2016 11:49:50
Ditto the above.
When I build mine, most of the mechanicals will get a repaint as the kit parts - although maybe the correct colour - look a little too 'flashy' for my taste.
But then I enjoy going potty with my builds anyway.
Roy.
Metal Mech
#4 Posted : 16 September 2016 11:57:44
Yeah I really don't plan to go that route. I am planning to build this model pretty much stock with only a few bits painted here and there. If I paint the intake then I pretty much have to paint all the parts that are that color on the engine.
#5 Posted : 16 September 2016 12:52:13
Once everything starts getting added to the engine block you will struggle to see it but if it does bother you then give customer services a ring for a replacement
70 Coupe
#6 Posted : 16 September 2016 18:34:45
Hi. By the time the rocker covers are on plus the carbs and air filter I think you'd really struggle to see the mark, but as stated earlier, if you're not happy, get it replaced...
#7 Posted : 16 September 2016 20:24:29
BigGrin One other thing to consider is that the Engine comes in several parts that are sprayed silver/aluminium so if you change the color of one part then the the others will need respraying too so the colors matchBlink Cool
#8 Posted : 16 September 2016 21:09:01
Which MetalMech has already stated himself in his post #4? BigGrin Flapper
#9 Posted : 16 September 2016 22:39:00
BigGrin Hi Kev
I see no harm in repeating that the consequences of painting one part could lead to more work to keep continuity in a buildBigGrin Flapper Flapper Flapper Flapper .
Best regards
AndyBigGrin Cool
Metal Mech
#10 Posted : 17 September 2016 01:49:38
Thanks for all the respons. If it's gonna pretty much be hidden once all parts are attached I am just not gonna worry about it.
70 Coupe
#11 Posted : 17 September 2016 13:33:50
Just been looking at my engine with all the aforementioned parts assembled and the area in question is in quite a large shadow, I think you'd have to be hyper observant and get a magnifying glass out to spot the mark. BigGrin
Hope this helps.
Metal Mech
#12 Posted : 18 September 2016 17:39:49
Hope this helps.
Much appreciated thanks.
Eagle
#13 Posted : 19 September 2016 14:24:35
Red Medal: Red Medal
Request a replacement; this is an expensive subscription, so if it bothers you have them send you another piece.
Metal Mech
#14 Posted : 20 September 2016 13:43:04
That's why I was asking. If the scuff was going to be highly visible when assembled I would ask for a replacement. If I won't notice it then it doesn't bother me and I can deal with it.
infidex
#15 Posted : 20 September 2016 15:42:16
If it bothers you now and it's not completely hidden, your going to continuously notice it even after built up, just because you know it's there. It's like painting a wall and messing up a tiny spot, nobody will ever see it but you will know it's there, you will see it, and it will bug you. If it was me, I would either swap it out, or as I read these thread, I would opt to paint all the metal/aluminum looking engine parts.
Current DeAgostini Model Space Builds:
Millennium Falcon; Sovereign of the Seas, Ford Mustang Shelby
Current "Other" Model Builds:
Bandai 1/12 C-3PO (Japan Import); Revell 1/48 X-Wing "Master Series"
On The Shelf Waiting to Be Started:
Revell 1/72 Millennium Falcon "Master Series"; Bandai 1/12 Boba Fett; Bandai 1/72 Y-Wing Star Fighter; Bandai 1/72 A-Wing Starfighter
This page was generated in 0.142 seconds.
