Planking the hull Options
daffy09
#1 Posted : 29 November 2010 16:40:00
Hello shipmates
Has anyone noticed any variance in the thickness of the planks (strakes)that are supplied?
As much as I've tried to achieve a smooth run of the planks, there seems to be some that are thicker than others. It looks like I've got an awful lot of sanding to do to achieve the finish of all the build diary photos that I've looked at and admired. My hull looks nothing near as smooth as those.
I completed the 'fairing' of the hull to the best of my ability and the run is alright with no high or low points ( well none that won't be sorted with the sanding ), it's just the different thicknesses of the planks. I suppose in hindsight I should have laid them out and checked them before attaching them to the hull ( just thought about that while writing thisCrying ) so I'll do that for the rest of the hull as I'm only just coming up to the upper gun deck height.
happy building
Daffy09
alantait
#2 Posted : 29 November 2010 17:33:12
funnily enough, i was just thinking the same as i am currently cutting out the second set of gun ports, i thought it was just me not doing enough fairing and that my sanding would straighten it all out, but thanks to your post i have checked some of the remaining planks and there is a slight variation.
ah well roll on the sandingLaugh
current builds
jonny7england
#3 Posted : 29 November 2010 17:56:39
Yup, I have some variations in the planking as well, glad I'm not alone on that one too..Blink
James
#4 Posted : 29 November 2010 19:23:33
Some of my planks are only about half the thickness of the others. Not really the standard we expect these days
Zeptrader
#5 Posted : 29 November 2010 20:12:58
If you come across the width of the planks vary, like this.
A very light sand will sort it.
Here is what I did, I laid all the planks out and from the picture you can see various shades, now this is not a problem, far from it, just beware if your like me going for a natural/stained hull, what you want to achieve is the 3 planks that make up a full layer of planks, they need to be the same shade.
All planks and shades
This close up you can see what I mean.
Take the last picture far right 2 planks, if you had those on the same layer it would stand out (if staining or Varnishing)
Just by choosing your 3 planks per layer you will get a nice uniform effect.
Also if your planks are different thickness, then add some packing to that plank.
Lakes74
#6 Posted : 30 November 2010 14:05:59
Rank: Amateur Level 1
Hi All,
Yep, I’ve had the same problem and was a little nervous about the unevenness of my planking. I ended up sanding a small part of the hull to test whether it would be fine with single planking. To my surprise it came out very well indeed! So I wouldn’t be too fussed about the thickness differences, just as long as there are no major gaps, you'll be fine. :-)
RussG
#7 Posted : 30 November 2010 17:11:12
Lakes74 wrote:
Hi All,
Yep totally agree there with Lakes74, it will sand out, any gaps could be filled with a good filler, especially if your painting!
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
willie
#8 Posted : 30 November 2010 17:33:20
i also had a few thick planks a scrape with a stanely blade held at 90 deg sorted that out be fore i cut the ports
Skipper
#9 Posted : 03 December 2010 15:07:09
Hi shipmates,
I would say I am heavily behind with my kit. I haven't started planking the hull. I had some experiences with other model kits I collected via magazine abonnement. Mad was as I received for one model kit (not Deagostini) a replacement piece with last magazine which was for one of the first issues. I had to dismantle whole model to make it work! Lesson learned that falling behind can have it's advantages. (Not only to survive in battles). Keep up with the good work and please share your experiences here further. I am a newbie and can tell you that my launch build already looks some different from the model. However, I am optimistic to achieve an acceptable result and will be brave starting planking the HMS V hull in two weeks time. The different wood colours give me concern now how to deal and sort them best. Will this have an impact on the painting? As said, I am no profi so have to paint anyway...it's unavoidable. Keep up with good work!
jonny7england
#10 Posted : 03 December 2010 15:31:58
Hi there Skipper, being some distance behind is the best place to be mate, what with any little problems that crop up, you will find there are brilliant tips and advice to be had from our esteemed shipmates, you will find this build not as daunting as it may seem...hope to see pictures of your build as you progress. hope enjoy your Victory build Skipper...BigGrin
