IJN Yamato Official Build - page 2 Options
admin
#1 Posted : 24 September 2010 16:15:16
BigGrin
#2 Posted : 01 October 2010 09:39:23
More Stern and Forward deck details added
#3 Posted : 05 October 2010 10:42:59
Outboard prop shafts fitted, though at this stage the shafts are only temp installed.
#4 Posted : 11 October 2010 09:37:22
The Funnel build
#5 Posted : 15 October 2010 10:14:12
The build of the display stand, I added pins into the pillar tops which wil secure the underside of the hull to the display stand.
Stand 1.JPG (795kb) downloaded 153 time(s).
#6 Posted : 20 October 2010 09:47:17
Aft range finder radar and tower build
#7 Posted : 25 October 2010 12:03:08
Assembly of bases for the superstructure, simple enough though filing and filling are needed.
#8 Posted : 01 November 2010 10:44:07
More superstructure
#9 Posted : 08 November 2010 09:37:46
Gun bases added to the superstructure bases
#10 Posted : 15 November 2010 09:20:44
Vent detail added, which are sandwhiched items comprising of a wood base, PE mesh and PE grille.
#11 Posted : 22 November 2010 09:22:34
More gun mounts added
#12 Posted : 29 November 2010 09:40:54
Start of the Tower build, though it won't be secured in place until all its detail has been added, the base plate is supplied later in the series and is needed to raise its height.
#13 Posted : 06 December 2010 10:35:28
Guns, straight forward enough and many of...
#14 Posted : 13 December 2010 09:11:56
Aft gun mount assembly, as before the vents are layered photo-etch brass.
#15 Posted : 30 December 2010 11:59:16
Forward gun mount assembly and photo-etch vents
#16 Posted : 06 January 2011 11:30:32
Guns - lots of them!
