Joined: 03/09/2012 Posts: 33 Points: 72 Location: Cornwall UK
Has anyone the best way of spray painting the camouflage for the spitfire, are there any stencils available ? or would hand brush painting be the best way
As mentioned in my PM, the blu-tak method is often used as seen in this video clip https://www.youtube.com/watch?v=tECZK1SFGE8
Joined: 03/02/2015 Posts: 457 Points: 1,389 Location: Crawley, W.Sx, UK
Hi Ron
I have found the best way is an aerosol, I use Humbrol with brilliant results.
Also White Tack is best for masking as it doesn't leave residue.
Hope that helps.
Alan PS you'll see the results of my spray painting in my build diary. There is a photo of the wing section in camouflage colours.
