beams between 6 and 8 Options
kaledonian101
#1 Posted : 26 November 2010 21:21:03
Hi, can anyone tell me if the 2 beams between 6 and 8 should be straight or curved down from 8 to 6?
budgie
#2 Posted : 26 November 2010 22:28:28
Hi Kal check official build diary post #8 you will see supports run at a slant
http://forum.model-space...lt.aspx?g=posts&t=89
kaledonian101
#3 Posted : 26 November 2010 22:36:03
Oh dear, after looking at official build diary and a few other posts, it seems i have 2 x number 8's.Confused
Time to try and fix it .
budgie
#4 Posted : 26 November 2010 23:07:02
Hi Kal on my first issue i recieved 2 frame 8s
Frame 7 does not have any locating lugs as there are no holes on deck for them to fit into(build instruction pictures confirm this)
frame 7 is not as wide as frame 8 also
I contacted customer services & got frame replaced with 2nd dispatch of parts
jinks8
#5 Posted : 27 November 2010 04:40:12
I to had 2 no8 in my first issue go a no7 in a later one as i have gone for the 11 issues can not rember if it was part 2 or part 3,4
Ninja-Bear
#6 Posted : 03 December 2010 12:04:09
I have the same issue but found that "n0.7" frame, despite being the same size as "n0.8" frame, has NO lugs, which is why it didn't become apparent until after glueing ! Have asked for a replacement part BigGrin
