Hi Shipmates, I'm a newbie, the Victory is my first wooden model. I'm doing the planking of the gallery support. After the last plank on the curved part a quite big gap left on my ship. If I try to put an other plank, it stands nearly vertical. Should I put this vertical plank there or leave the gap and the planks of the hull will cover this gap? See photos:   Thanks for your help.
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
hi ginger ale..taper a piece of plank so it fits in the gap or if the plank fits in the gap on its edge fit it then trim it off flush with the ones that are there already...paul cheers benny
