Next stage was to attach the mainsail. Decision had to made here as to how the sails should be presented, whether furled, partially furled or fully opened. The person this ship is going to finally decided he wants all the sails to be fully opened and has asked that the sails look as if they are billowing. Giving the appearance of wind in the sails will be carried out much later but for now I just concentrated on the fitting. First step was to lash the sail to the yard, quite a straight forward process. Made up the parrel and attached one end to the yard, wrapped it around the mast and secured the other end to the yard ensuring the parrel trucks were facing the right way. Made up and attached the halyards, securing the lower ends to eyebolts set in the deck after threading it through the bit. Tensioned this after fitting the other end to the yard. Moved onto fitting the lifts on both sides, securing these to the middle belay pin in front of the mast. Attached blocks to the forward shroud then fitted the mainsheets, these were secured to the belay pin on the bulwark, port and starboard. Finished fitting the sail by fitting the port and starboard brace tied off to the rear belay pins on the upper quarterdeck. Last item for the sail was to fit the sheets, these were left loose. Added some rope coils to the decks and some of the used belay pins just to give that finishing touch. Finally added some more bling and this brought issue 124 to a close. That’s all for now so happy modelling all… Regards Alan Gandale attached the following image(s):
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
That looks amazing, Alan. She is really coming together now. The sail does hide some of the detail though. Will have to think about how I want to do that when I get to that stage. Just makes me think about how far I have to go yet. Can't wait to see more. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Very nicely done Alan it's nice to see the old lady getting her sails on Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Alan. stunning work. the sails are looking great. Look forward to the next update. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Beautiful work Alan, she is looking fantastic. Graeme
Great to see another update Alan, this truly is an amazing looking build that's been a real pleasure to follow :)
Thanks guys for looking in and for all your kind comments, it's always appreciated... Will update again soon....
Joined: 22/08/2016 Posts: 56 Points: 164 Location: Tyler, Texas
Looking awesome, spent a good chunk of my lunch break today scrolling through all the pages of your build. I can't wait to get beyond the planking phase I'm soon to start and into the details of this build. Current DeAgostini Model Space Builds: Millennium Falcon; Sovereign of the Seas, Ford Mustang Shelby
Current "Other" Model Builds: Bandai 1/12 C-3PO (Japan Import); Revell 1/48 X-Wing "Master Series"
On The Shelf Waiting to Be Started: Revell 1/72 Millennium Falcon "Master Series"; Bandai 1/12 Boba Fett; Bandai 1/72 Y-Wing Star Fighter; Bandai 1/72 A-Wing Starfighter
Another great update Alan, really nice to see the sails start to go on. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
infidex wrote:Looking awesome, spent a good chunk of my lunch break today scrolling through all the pages of your build. I can't wait to get beyond the planking phase I'm soon to start and into the details of this build. Thanks for your kind comments, appreciated... My advice to you would be to read everything twice and make sure you fully understand what is required for each stage of the build before doing any of the work... Take your time, there's lots to do and patience is key. Do this and I'm sure you'll end up with a build you can be proud of.... I'll be following... Regards Alan
Gibbo wrote:Another great update Alan, really nice to see the sails start to go on. Regards Paul Thanks Gibbo, slow but steady progress... The end is in sight but still some way off yet..... Regards Alan
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 04/04/2013 Posts: 89 Points: 270 Location: Stroud, Gloucestershire
lovely work and model m8 one to be very proud of Current builds :
AL's HMS Surprise Model Shipyards HM Cutter Mermaid
Thanks Ant, appreciate your kind comments.... Started stage 125 with the adding of more belay pins onto the bulwarks followed by fitting additional eyebolts onto the quarterdeck, this was quite a fiddly process due to lack of space. Attached the Topsail and Topgallant sails to their spars in preparation of fitting to the mainmast. Made up the halyards and collars, fitting them to the eyebolts previously fitted, again a fiddly process but got there in the end. Attached the Topsail to the mast, Halyards were then fed up through the tops, over the mast caps, back down to and attached to the spars. Have to say one or two expletives were expressed from time to time while doing this. Moved onto fitting the lifts securing to the belay pins on the rack in front of the mainmast. Had to attach additional blocks to the shrouds in order to fit the braces and sheets, securing to the belay pins fitted onto the bulwarks. Once this was done for the Topsail moved on and fitted the Topgallant sail in the same way. Stage 125 now complete, now to get on with stage 126. Happy modelling all…. Regards Alan Gandale attached the following image(s):
Looks really superb Alan excellent  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Stunning work as always Alan looking forward to seeing your next update Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Great work Alan, she looks fantastic. Graeme
Hi Alan. Looking fantastic. Look forward to seeing your next update. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
It really is a stunning piece of work Alan You mentioned that it will be going to a new home, is this a family member or have you sold it? Either way Im sure they are going to be over the moon with the finished result.
That`s looking WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Once again guys, thanks to all who looked in and passed their kind comments, much appreciated.... @Dave, I love building these ships but unfortunately I don't have the room to display them so this one is going to go to a colleague who has a display area within his lounge, a display area that will do it justice...  . He simply wants all the sails to be fully displayed.... Regards Alan
