9 Pages «<34567>»
Pearl Harbor 75 - complete! Options
#81 Posted : 31 August 2016 17:14:18
Cheers Kev
So I said I will be doing minimal weathering on the ship, but the anchor races will need some weathering.I decided to use the salt weathering technique.
Here is the technique.
Step 1 prime the part and then spray it steel colored. There is a photetch part that replaces the kits anchor races so it makes it easy to do the weathering without having to mask off the deck.
#82 Posted : 31 August 2016 17:17:49
Salt weathering technique step 2
The next step is to get a sponge and cut off a small pieces of it.This will be used to apply the rust paint.I use Vallejos rust and steel weathering set.It has a couple of different colors of rust.
using the sponge I applied the first rust color randomly over the part.
#83 Posted : 31 August 2016 17:19:58
Salt weathering Step 3
Once the first layer of rust paint has dried I repeated the process using a different rust color.Once this layer had dried I mixed the 2 colors to make a third rust color and dabbed it over the part with the sponge.
#84 Posted : 31 August 2016 17:25:35
Salt weathering Step 4.
Once the paint has dried we will be applying the salt.I used rock salt.This comes with a grinder in the cap so you can make different sizes of salt granules.I made various sized pieces of salt with the grinder and then wet down the part with water and sprinkled the salt over the part.I tried to concentrate on placing the salt where I wanted the rust to show through.
Once the water had dried ( a few minutes) I sprayed the hull color over the part and once this had dried I gently scraped the salt off the part to reveal the rust.
#85 Posted : 31 August 2016 17:28:11
Salt weathering
Here is the finished part once the salt was scraped off.If gives a nice natural looking weathered effect.
#86 Posted : 31 August 2016 17:30:13
Most of the deck pieces have now been added and I test fitted the main guns and motorboats.
#87 Posted : 31 August 2016 17:32:15
Very nicely done with the weathering Carl looking good
#88 Posted : 31 August 2016 18:19:22
Great tutorial Carl, it came out looking really nice.
I always wondered why they would paint the tops of he turrets in bright colours, it always seemed to me like it was painting a target on them
#89 Posted : 31 August 2016 18:25:13
The turrets were painted for identification purposes for the spotter planes.Each battle group had a designated color so when the spotter planes came back from a mission they knew which ship to land next to.Arizona battle group had red as their color
#90 Posted : 31 August 2016 18:26:05
Nice work indeed, the salt technique works really well, hairspray is good for a finer type of weathering. Really coming along now.
#91 Posted : 31 August 2016 18:32:22
I will be using the hairspray technique for weathering the anchors Nemesis.
#92 Posted : 31 August 2016 18:40:10
Nice work on the beast Carl
#93 Posted : 31 August 2016 18:52:46
This is coming on nicely. WTG
Excellent weathering tutorial as well.
#94 Posted : 31 August 2016 19:51:38
Very neat bit of building i must say. Adding all of those exteas can show up fit issues but yours looks a "million dollars" and shows some real building skills.
#95 Posted : 31 August 2016 21:23:55
Excellent tutorial Carl ending with a great result.... superb work throughout.....
#96 Posted : 01 September 2016 07:15:57
Looking great,
i can see the idea behind the red turret tops though this also makes it very spotable by enemy aircraft
#97 Posted : 26 September 2016 18:50:36
I havent forgotten about this build.There will be a major update very shortly.I have been painting all of the rest of the deck superstructures.The Vallejo paint does not like humidity and it has been very humid here.I had to respray some parts because the paint didnt cure properly. I am almost done painting and then it is on to assembly of the rest of the decks.
#98 Posted : 26 September 2016 21:57:00
I didn't realise that survivors of the Arizona from Dec 7 1941 can have their ashes placed aboard the Arizona and be returned with their shipmates.
#99 Posted : 26 September 2016 22:13:32
Yes and at the memorial site at Pearl Harbor the Navy does not tolerate any disrespectful behavior from tourists since this actually is a burial site
#100 Posted : 26 September 2016 22:30:43
You're doing this great justice Carl, she's looking very impressive....Drool Drool Drool
9 Pages «<34567>»
This page was generated in 0.208 seconds.
