Battery care Options
#1 Posted : 31 August 2016 14:43:50
Please note, the battery is shipped as being 30% charged, this is due to air freight regulations.
The battery should be charged within 180 days of receipt, otherwise over time it will self-discharge and a full re-charge required.
Note - Ensure that the Battery/Robi is not stored or set aside in a discharged state as this may damage the battery which may cause a re-charge problem.
Charging for the first timne should take abiut 1.5hours, thereafter it should take about an hour depending on battery status.
Robi run time is dependent on what he is doing. If a high power constant movement such as dancing, his power will quickly depleat to 8 - 10 mins run time, his power for other operations may last for up to 40 mins.
AltimitWIll
#2 Posted : 07 May 2020 04:31:03
Rank: Newbie
Is there a way to upgrade Robi’s Battery to a longer lasting battery?
AdamE
#3 Posted : 20 September 2021 00:25:04
Rank: Advanced Member
I am working on this now! I am fed up with the short run time my Robi's have.
This page was generated in 0.083 seconds.
