19 Pages <12345>»
Tom Options
jonny7england
#41 Posted : 24 November 2010 09:01:22
Looking real good mate...ThumpUp
tom.ganc
#42 Posted : 31 December 2010 16:11:39
Hi shipmates,
I was a while since my last post but I was busy doing... planking :)
I've got my hull nearly finished now, only few more rows of planks (I hope to get issues 35-38 next week so I'll finish it off)
First of all take a look at this. I'm duing gunports Zeptrader's way and I've tried to paint it just to check the result. Have a look
By tomganc at 2010-12-31
And now have a look at the planking itself. I gave it rough sanding, but propper one will be when all is finished. Planking is far from being perfect but I'm happy so far. It is my first planking ever and I must admit I know I messed it up a little bit but I don't really care. It will be copper plated anyway.
Have a loook
willz
#43 Posted : 31 December 2010 16:31:54
nice going, looking fine. keep the pics coming.
Willz
tf5600
#44 Posted : 01 January 2011 12:20:39
Looking great Tom, i have just finished cutting gun ports,so quite a bit behind everyone, it will be nice to get something different in the issues, i have got planks everywhere.Keep up the good work.
Ferret
#45 Posted : 01 January 2011 12:38:26
really fab build I am just about to embark on lower hull planking hope I can do as good a job!BigGrin
jonny7england
#46 Posted : 01 January 2011 14:58:02
Looking pretty good Tom, I am still stuck on issue 29 and had been since when the missus took a tumble and done her back in a number of weeks ago, of course, my work area is in the bedroom where the wife is laid up, so the build has been put on hold until further notice...Crying
Keep the pictures coming mate... ThumpUp
tom.ganc
#47 Posted : 03 January 2011 22:42:17
Hi there again,
I've ran out planks so I've decided to get some gunports framing. As you've notticed before I'm doing gunports Zeptrader's way. I cut them to 10mm square and I'm inserting inner frames (9mm square). When gunports closed they will be flush with the hull.
I've done lower ports framming but it was really time consumming so I've decided to do something about it. Because I've had some scrap planks left I've decided to do use them. Have a look what I mean.
By null at 2011-01-03
Right now I need to glue them in position and job done :)
benny
#48 Posted : 04 January 2011 19:05:58
looks great..nice work with the port frames..i will look forward to when there fitted...benny
cheers benny
tom.ganc
#49 Posted : 16 January 2011 23:00:03
Hi there
Finally... I've finished hull planking BigGrin BigGrin BigGrin
Right now I need to sand it down little bit, finish off port framming and sand, fill, sand, fill ... Bored
I'm happy man now. Cool
Pics to follow
tom.ganc
#50 Posted : 30 January 2011 03:57:17
Hi there
As I prommised in last post please have a look on my finished hull planking. It needs some more filling and sanding but it looks good so far :)
By tomganc at 2011-01-29
I've tried to frame gun ports using profiles made from spare planks but it didn't work out as good as I planned. Instead I've used 1mm2 stock and made them quite quickly. I'm not framing upper gun ports yet. There is enough access from both sides to do it later.
Have a look what I've got so far
See you next time :)
Foz
#51 Posted : 30 January 2011 08:31:10
Looking really smart tom. Ive just started the lower planking and finding it hard going and time consumeing.
Keep up the good work and keep the pics comming
Foz
benny
#52 Posted : 30 January 2011 10:20:17
nice job on the ports tom.and looking very nice overall...benny
cheers benny
farrabass
#53 Posted : 30 January 2011 15:42:04
The gunport framing has turned out quite good!.
I am still planking the lower half of the hull and framing the gunports as I go along, are you aiming for a natural finish or a painted one?, you might be able to get away with a bit of filler if the wales overlap the filled part, if your painting it doesn't matter, fill to your heartss content.
Cheers Steve..
tom.ganc
#54 Posted : 30 January 2011 16:51:01
Hi Steve
I'm going for painted finish but I don't want to use filler too much. Even after painting I want wood texture to show up little bit.
I've used just little bit of that white filler just to check it how it looks like after sanding.
Only one row of ports needs framing now and I'm sorted :)
Hopefully next 4 isuues will arrive this week :)
tom.ganc
#55 Posted : 08 February 2011 00:59:53
Hi there again Cool
I've managed to get some more work done on my Victory. I've got both sides sanded (it needs some filling and fine sanding but I'll do it later) and gun ports framed.
Entry ports are not ready yet but I'm currently working on them.
As you will see on the pictures I've done some "kit bashing" BigGrin on the deck. I'm getting ready for another deck planking (Issue45) but because of the cutout in the hull I needed to put some details there. It's not finished yet though.
I'm not going to leave original deck planking, but I'm going to glue on top of it 3mm planks as I've done so far. It looks much better to me.
Please have a look
By tomganc at 2011-02-07
farrabass
#56 Posted : 08 February 2011 01:21:28
Very nice Tom, you have really adopted this build as your own.
Exceptionaly smooth lines at the bow/front, I see you have not followed the build instructions in regard of the placement of the hull planking, but nonetheless looks very very goodLove .
The way you have planked the lower part of the hull is very similar to the way I finished my last build, this time I am trying to emulate the official build, but either way it's the end that counts.
Many congratulations on an interesting diary..BigGrin
tom.ganc
#57 Posted : 17 March 2011 16:49:33
Hi there
I wasn't here for a while but I was busy.... building BigGrin
I'm on the stage of rigging the guns and I didn't like the size of blocks supplied in magazines so I've ordered some 2mm ones. I think they look great with this canon. Have a look yourself.
Blocks supplied with magazines
2mm blocks
Son of Bulwark
#58 Posted : 17 March 2011 17:48:28
Hi Tom! Cool
You're right the 2mm block are more in scale than the 5mm one's supplied.
benny
#59 Posted : 18 March 2011 20:40:47
2mm blocks it is then
cheers benny
Foz
#60 Posted : 19 March 2011 17:59:27
The 2mm blocks do look a lot better. May i ask, silly question as new to this, which ones you got, from were and how many will we need.
Keep the great pics coming, lovely looking build.
Foz
19 Pages <12345>»
This page was generated in 0.185 seconds.
