Huracan - Receiver battery pack - now on sale! Options
#1 Posted : 23 August 2016 10:21:39
As noted in the instructions of Pack 12 at Stage 30 - for the operation of the RC system on the chassis, you will need a rechargeable 6-volt 1600mAh 2/3A Ni-Cd or Ni-MH (Nickel-Metal Hydride or Nickel Cadmium) “in-line” receiver battery pack with JST (BEC) male plug to suit the JST female socket of the on/off Switch harness.
You will also require a compatible Charger and should ensure that your chosen battery pack is of a suitable size to fit into the battery box on the chassis.
These items are available as a complete set (battery pack & charger) via the ModelSpace online shop:
http://www.model-space.c...-smart-charger-kit.html
Specifications:
Extreme Power rechargeable 6-volt 1600mAh 2/3A five cell Ni-MH battery pack. Includes a JST (BEC) adaptor lead for connection to the charger.
Intelligent 500mA smart charger:
The Smart Charger is designed to charge Nickel-Metal Hydride or Nickel Cadmium ( Ni-Cd or Ni-MH) 4-10 cell battery packs. The Smart Charger has a microprocessor-control system which can distinguish a 4~10 cell pack automatically and cut-off the charging accordingly, manual-adjustment is not needed.
Cell life is protected by –dV detection and timer protection.
LED display for Rapid charge/trickle charge
Red LED- rapid charge
Green LED- Fully Charged & trickle charge
Flash Red and Green LED- short
Flash Red LED: Reverse polarity or Wrong Battery
Safety features: -dV cut-off function
Note - The charger has a UK 3-pin plug and is rated at 220/240volt input.
