11 Pages <12345>»
Time machine 2002 Options
#41 Posted : 12 August 2016 20:23:09
Wow lovely work Carl your scratch building is stunning
Nytetrain
#42 Posted : 12 August 2016 23:15:07
Looks great so far Carl. Was looking forward to watching this build since you announced it. Keep up the good work.
Ron
Best Regards,
Ron
In the Stash: Losing count...
#43 Posted : 14 August 2016 19:38:36
Thanks everyone.
The Time Machine has 2 "batteries" which site under the platform.The batteries themselves are resin pieces.I added copper wire and regular wire and used zinc oxide tape to make the insulation around the wires.
#44 Posted : 14 August 2016 20:18:56
Very nice work and looking good
#45 Posted : 21 August 2016 14:45:06
Thanks Andy.
The base is now finished.The next step is to mount the parts on the base and under the platform.The batteries mount under the platform and connect to control boxes mounted on the base.
#46 Posted : 21 August 2016 15:14:18
Beautiful work. It's coming along nicely. Can't wait to see the end result.
#47 Posted : 21 August 2016 15:42:55
Your attention to finishing each of the component parts is stunning.
It looks wonderful
#48 Posted : 21 August 2016 17:12:49
Nice work now the paints going on its transforming the beast
#49 Posted : 21 August 2016 22:16:29
This really is stunning work Carl and a joy to watch coming together
#50 Posted : 22 August 2016 00:05:05
Gets better and better every time I look in, great work.....
#51 Posted : 22 August 2016 10:48:04
Superb work on the base, it looks amazing. The batteries will really look the part when finished, very well done indeed!
#52 Posted : 22 August 2016 15:20:37
Thanks everyone for your kind words.
The final part of the assembly under the platform is to build 2 tanks.These come in 2 parts and with a gauge. I bought some threaded rod for the mounts.I will paint the tanks a copper color and leave the rods their natural brass color. Once they are finished I have to test fit and figure out where everything goes.I made the platform slightly bigger than the kit one so I should have room for all of the parts.
#53 Posted : 22 August 2016 15:25:48
Really like what your doing/ superb build update ........regards Phil
#54 Posted : 22 August 2016 20:14:14
It really looks a complex kit but you seem to know exactly what to be doing to put together a stunning build.
Just so impressed with the base you have put together.
#55 Posted : 30 August 2016 16:51:59
Thanks everyone.
There are 2 control boxes that connect to the batteries and sit under the platform.
One of them has a gauge on it.The kit does not come with any decals so I found some pictures of gauges on the internet and printed them on photo paper. I then cut out the gauge with a leather punch and installed it on the kit part.
Once the copper tanks are finished I will need to test fit all the pieces that go under the platform and attach them.After that I will start building the structures on top of the platform.
There is a brass rail around the platform.This does not come with the kit.there are mounts to connect the rail to the platform.I bought a piece of copper wire which I will use to make the rail and then I will spray it brass colored.
#56 Posted : 30 August 2016 16:55:17
Great idea for the gauge faces, it will really add to the detail. Nicely done!
#57 Posted : 30 August 2016 19:26:45
Have to agree, those gauges are real good.
Nice job so far, looking forward to more updates.
#58 Posted : 30 August 2016 19:58:34
Those gauges are awesome!! I'm guessing you just stuck them on with something like PVA?
#59 Posted : 30 August 2016 20:07:26
Just a dab of superglue swished around with a brush.
#60 Posted : 30 August 2016 20:21:41
Very nice
11 Pages <12345>»
