She's looking great Adam, you've certainly done a great job so far and long may it continue.  The art of fitting droppers and stealers does take a little time to master but with perseverance I'm sure you'll get there in the end. It doesn't matter how long your build takes just as long as you are enjoying the experience....  .. Look forward to seeing your next update.... Regards Alan
Adam Its all coming on well. Ups and downs with any build are to be expected but the end result proves so satisfying. Hope the rest of the build goes well. Happy Modelling
 Rank: Pro     Groups: Registered
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi Adam Good to see you back at last! Your second planking is looking absolutely immaculate. Love the neat finish around the transom. I had a lot of bother with this area but you've done a lovely job...Well done... Can you tell me what droppers and stealers are? I haven't a clue! Regards JohnP
John Passmore wrote:Hi Adam Good to see you back at last! Your second planking is looking absolutely immaculate. Love the neat finish around the transom. I had a lot of bother with this area but you've done a lovely job...Well done... Can you tell me what droppers and stealers are? I haven't a clue! Regards JohnP Hi John, have a look here... Excellent guide to planking for beginners and fully describes the use of droppers and stealers....  .. Hope this helps. http://forum.model-space...aspx?g=posts&t=5669
Regards Alan
Nice and neatly done planks. Your doing a grand job. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 17/04/2014 Posts: 99 Points: 303 Location: Perth, Western Australia
Very many thanks for the preceding comments. They are certainly appreciated and definitely helps to maintain an eye on the prize, so to speak, in completing this stage of the build. I’ve continued with the second layer of planks over the past month or two. About 5 more rows to go. A long haul so far I must admit, but there is light at the end of the tunnel (and it’s not the oncoming train). Now I need to figure out the best approach for laying the planks around the T-Junction that is the hull and stern post. I’ve planked from the keel down (or is it up? Been working on this upside down for too long). I think I need to progress inward continuing from the last of the 14 rows previously laid. There looks to be some serious twists and curves in a small area. So, short and sweet for now. Until next time - take care. Adam AdamHall attached the following image(s):
Hi Adam
Lovely planking work there mate - looks absolutely immaculate...
Don't worry about the planking round the stern post - just let the planks lay where they want to go, then just put shaped infill pieces in as required...that's what I did.
Regards JohnP
PS. Where have all the smiley's gone?
Stunning work on the planking Adam looking sweet. Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Top work there Adam and yes, the stern area can be a little tricky to do but looking at your progress to date I think you'll get round that area without too many problems.... Looks fab...
Hi Adam. your planking is looking excellent, keep the pictures coming. regards Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Absolutely beautiful planking, but I can see a problem on the horizon.You have made such a good job on bottom of hull, are you really gonna want to cover it with paint? Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
Hi Adam
Stunning work with the planking, they're so neat and tidy!! Looks like a lot of love and patience has gone into doing it
Really nice work there Adam...Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Ahoy there. There is quite a buzz in the dockyard at the moment and it gives me much pleasure to announce that THE SECOND PLANKING ON THE HULL IS COMPLETE. There is no way I thought it would take this long to complete, but perseverance appears to have paid off. Almost all of the bow planks were tapered to be ending at half width (2.5mm). Some have pointed ends but these are hardly noticeable. The transition of the planking at the stern post gave me the most grief. To help achieve a flowing transition I decided to flare out the top of the stern post with wood putty. This helped immensely as the planks are bent and twisted within a small area. The hull has been lightly sanded using 400 grit then 800 grit sandpaper, so now it is silky smooth. So, now it is time to crack on and commence construction of the gallery and transom. But before we do, to celebrate the completion of this milestone, the Captain has issued an order to the dockyard crew: “Splice the Mainbrace” AdamHall attached the following image(s):
WTG Adam, That looks to be a top job on the planking. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Very nicely done Adam she is certainly looking ship shape. Well done m8 Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Very nice job on the planking there, Adam. I'm sure it must fell great to reach this milestone in the build. I am just starting this build and will definitely be watching your progress with interest. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Looking good Adam, you've certainly done a great job with the second planking layer. Well done....
Adam Time and patience has indeed paid off and you now have a great hull as the foundation of the rest of your build. Hope it all continues to go well. Happy Modelling
Beautiful planking, as others have already said your patience really has pad off.
If the rest of this is done to this standard it will be a stunning show piece when you get done with it
