 Rank: Pro Groups: Registered
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
Hi Mr T hoping you can answer my quiery do you happen to know the width of the exterior keel I take it it should fit into the gap in the bow planking many thanks
The real keel is 6mm wide, the gap at the bow (curved stem gap) will be adjusted to suit as will the garboard plank, at issue 39 which is where the keel strips, curved stem and stern post are fitted.
 Rank: Beginner Level 3  Groups: Registered
Joined: 07/05/2010 Posts: 25 Points: 96 Location: Sussex by the Sea
Thank You Mr T that has just answered one of the questions that has been in the back of my mind.
John
