Finishes Options
Tiswas
#1 Posted : 20 November 2010 18:03:22
Looking at the members build projects, a lot of the planking looks very smooth? Are you all filling and sanding as you go along or is the camera angle that makes them look so smooth?
TIS
Zeptrader
#2 Posted : 20 November 2010 18:14:36
Hi Tiswas, for me just careful planking and no filling.
I do think the camera angles on some shot (mine) do look smooth, BUT I will be snading once planking is done, I'm not after perfection..yet, I think a very small amount of difference in the planks does make it look good.
benny
#3 Posted : 20 November 2010 19:29:38
hi tis..not sure if you looked at mine but i planked then gave it a good sanding and filled if needed i then gave it a coat of paint to show if more filling was needed,with my build i am second planking with 0.5x5mm walnut planks so all i am after with the first planking is a good base..cheers paul
cheers benny
amipal
#4 Posted : 21 November 2010 12:28:17
Though I haven't even started planking yet (yes, I'm a bit far behind at present), I'll be filling and sanding as I go along. My Victory will be fully painted at the end though.
ArtfulBodger
#5 Posted : 21 November 2010 14:33:40
Benny
I'm following you with second planking. I haven't made my mind up about 0.5 x 5mm or 0.5 x 4mm, your views would be appreciated.
Seconding I wondered whether oak planking would be better as walnut is very dark.
Since my arm is out of action I've got time but I thought I'd just ask.
ArtfulBodger
Previous Build:
HMS. Bounty
#6 Posted : 21 November 2010 14:40:11
Hi Artful
Walnut is alright really, I'm using on my Surprise build and find it fairly light. My mahogany ship is darker..
Chris..BigGrin
benny
#7 Posted : 21 November 2010 16:43:37
ArtfulBodger wrote:
Benny
the original planking is 2x5mm so 0.5x5mm veneer would make sense cause i am not filling the second planking i want to see the lines of the planks through the paint..cheers paul
cheers benny
jonny7england
#8 Posted : 21 November 2010 17:17:29
TIS
Hi Tis, I was thinking along the same lines as you mate, I am not overly too pleased with my planking, a number of my planks are just a fraction proud of some of the other planks, at first I thought that the strakes might have been a tad thicker than the rest, and the thought of ripping off all the planks and starting again had crossed my mind a few times, but I shall sand and use multi-purpose wood filler to right any unevenness as my finished Victory will be painted...good luck on your build mate...
This page was generated in 0.130 seconds.
