4 Pages <1234>
Michaels USS New Jersey Options
michael.rolph
#41 Posted : 15 August 2016 19:50:01
Sub gun detectors
The sub gun detectors were cleaned up and the existing detail filed off.
Picture 1
PE plates were shaped and glued into position. PE ladders were then added to both sides of the detectors.
Picture 2
The existing dish connectors supports were trimmed and the supports replaced with PE.
Picture 3
The tops of the dish connectors were glued on top of the supports.
Picture 4
The dishes were added to the detectors and the detectors added to their stands.
Picture 5
michael.rolph attached the following image(s):
michael.rolph
#42 Posted : 15 August 2016 19:51:02
Bridge 1
The bridge was removed from the sprue and cleaned up, it was as this point I realised it wasn't quite the right shape and discovered that there were two bridges in the box. The correct bridge was then cleaned up and the plastic window molding removed.
Picture 1
The top section of the bridge was cleaned up and the PE for the windows and walls added to the bridge base.
Picture 2
PE details were then added to the top section, there is still several pieces to add.
Picture 3
Top and bottom sections were test fitted.
Picture 4
This platform connects the back of the bridge to the first cooling tower
Picture 5
#43 Posted : 15 August 2016 20:30:31
Very nice work and looking good
#44 Posted : 15 August 2016 22:30:08
Looking good Michael, nice work....
#45 Posted : 16 August 2016 00:44:44
Lovely job so Michael.
I've just looked back at some of older pictures and what jumped out at me was the amount of clean up you have to do, there's certainly a lot of flash on some of those sprues
#46 Posted : 16 August 2016 08:29:55
#47 Posted : 16 August 2016 11:45:56
Well impressed with how you are using the etch on this build.
So easy at these tiny scales to overdo the glue but not a bit of that in your build. Very skilled bit of building.
#48 Posted : 16 August 2016 22:37:31
Nice job of the photo etch. Lovely job overall. Loving your build.
k8 vnl
#49 Posted : 20 August 2016 11:54:00
Nice work I not done a ship in ages.
Built and building
All things Airfix & Revell.
michael.rolph
#50 Posted : 05 October 2016 21:37:44
Time for another update, I'll have to pick up the pace a bitif I'm going to finish before the December deadline.
38 Mk.28 Twin Guns
I removed all the pieces and cleaned them up.
Picture 1
The barrels of the guns were removed and replaced with brass.
Picture 2
Truly quality instructions on the left side it tells me to glue the gun in place and on the right it tells me not to glue the axle so it could pivot.
Picture 3
The sides were glued in place the fit was quite poor.
Picture 4
The gaps were filled with liquid green stuff and the bottoms filed down.
Picture 5
Finally I added the remaining pieces of etch.
Picture 6
michael.rolph
#51 Posted : 05 October 2016 21:38:47
Radar tower
The tower was constructed from three pieces the platform was dry fitted to get the top part correctly lined up.
Picture 1-3
The platform topper was shaped and railings added
Picture 4
The antenna was quite fiddly
Picture 5
It was quite difficult to fit the framework to the back of the main radar.
Picture 7-8
michael.rolph
#52 Posted : 05 October 2016 21:39:31
Fuel tower
The tower was assembled and extra plastic detail removed.
Picture 1
The PE pipe was attached,
Picture 2
The remaining PE was added
Picture 3-4
michael.rolph
#53 Posted : 05 October 2016 21:40:31
Rear Funnel
The PE walkway was added.
Picture 1-2
The funnel was added to the tower
Picture 3
The remaining PE was attached
Picture 4
michael.rolph
#54 Posted : 05 October 2016 21:41:51
Tomahawk missile launchers and platform
Quite a lot of PE these pieces
Picture 1-8
Misc
The misc bits of detail of the main deck has been prepped for painting
Picture 9-10
#55 Posted : 05 October 2016 22:50:52
Lovely work with the etch Michael, really coming along very nicely indeed....Cool Cool
#56 Posted : 06 October 2016 20:12:41
Nicely done Michael Cool
Those fit issues are shocking Blink you've done a great job of fixing them though Cool
michael.rolph
#57 Posted : 23 November 2016 22:50:23
Time for a update, most of work has been painting the sub assemblies.
Transfers
Before I could progress with further assembly of the ship I had to apply transfers to the hull, deck and island. Without doubt the transfers provided are the worse I have ever encountered. A lot of the transfers simply broke into pieces, parts simply would not separate from the backing paper. Luckily the helipad transfer came off with just a slight tear. Because I lost most of the red stripes for the deck I had to improvise. I attached double sided tape to some white paper then painted it with the same red that I used on the hull. This was cut to length and place on the deck.
Picture 1
Assembly
The instructions call for the whole island to be completed before it is added to the hull. I decided because of the etch and rather poor fit I needed to attach it before I did any further work on it. After a test fitting I found that the deck was sagging in the centre. I added wood supports then attached and clamped two pieces together.
Picture 2-3
michael.rolph
#58 Posted : 23 November 2016 22:51:13
Deck detail
There was quite a lot of etch railings to add. I still have some elements to add such as ladders.
michael.rolph
#59 Posted : 23 November 2016 22:52:20
Tower assembly
The tower was assembled and attached to the island. It's now stating to look like a battleship
#60 Posted : 23 November 2016 23:11:52
Nicely done Michael, great progress.....Cool Cool
4 Pages <1234>
This page was generated in 0.289 seconds.
