8 Pages «<678
Rockwell b1b bomber Options
#141 Posted : 13 August 2016 19:10:44
The doors look great, nice work.
#142 Posted : 13 August 2016 21:00:00
Nice work on the doors Mark, glad you took the time to fill and sand those ejector pin marks, always a job worth doing and your scratchbuilt bars look very good, a nice bit of extra detail to enhance the finished model - very well done!!
How did you get on with varying the grey tones in the cockpit painting that you did? Turn out any better?
Keep up the good work mate, watching with interest as always.
Kev
mark 2
#143 Posted : 14 August 2016 09:50:02
Nice work Mark, coming along very nicely...
Hi Alan
Thanks for looking in and great comments.
Best regards.
mark 2
#144 Posted : 14 August 2016 09:53:06
Nemesis wrote:
Top work on the doors, really coming along. Well done!
Hi Nem.
Thanks for looking in and fantastic comments.
Best regards.
mark 2
#145 Posted : 14 August 2016 09:54:47
Hi Andy.
Thanks for the great comments and looking in.
Best regards.
mark 2
#146 Posted : 14 August 2016 10:03:19
Kev
Hi Kev.
As you said the doors will look great when sprayed with the top coat.
At the moment I am still in the process of doing the cockpit and I am using the Revel aqua range but I cant get on with them as they are so thick and the pigments are so very coarse. I will look into the Tamiya or mig range.
Best regards.
#147 Posted : 14 August 2016 12:39:40
Hello Mark,
I don't like the Revell Aqua paints either, the thickness can be dealt with by thinning, but they do use very coarse pigments!! The Tamiya paints are excellent as are Vallejo paints though Vallejo tend to need at least a day to harden otherwise they can sometimes rub off, though once hardened properly they are very tough!?
Kev
#148 Posted : 14 August 2016 19:14:33
The only Revell aqua I use is the rust, brilliant for base coat on exhausts, apart from that they don't get shelf space! For airbrush I use Tamiya, Mig and Vallejo, and for detail brush work I use the aforementioned.
mark 2
#149 Posted : 15 August 2016 06:02:01
Hi Kev and Nem.
I think you both are wright. I wont be using them again and they are going straight in the bin where they belong.
I think I will go with the Tamiya and look at the Mig and Vallejo range.
Thank you both for your help and advise which is greatly appreciated.
Best regards to both of you.
8 Pages «<678
This page was generated in 0.105 seconds.
