5 Pages 123>»
Rob's Soleil Royal build diary Options
RobT
#1 Posted : 11 August 2016 20:44:51
This is my thread for my build of the Soleil Royal. I have no pics yet, but I'm starting it now as I have just taken the first small step of a long journey by placing my keel in soak for 24 hours prior to clamping over the weekend to flatten it.
Hopefully I can glue my first piece in anger on Monday.
#2 Posted : 11 August 2016 21:00:53
Looking forward to seeing your build Rob have fun
RobT
#3 Posted : 11 August 2016 21:13:17
Thanks Martyn.
#4 Posted : 11 August 2016 21:48:11
Excellent another build looking forward to seeing your progress
eebygum
#5 Posted : 11 August 2016 21:49:11
Welcome aboard looking forward to the build
Terry
#6 Posted : 11 August 2016 22:04:13
It'll be great to follow your progress Rob, good luck with the build....
#7 Posted : 11 August 2016 22:45:20
Good luck on your build Rob. Hope the keel straightens out for you. Try and keep it at room temp also a few hours in warm water is all it should need. Just be aware they sometimes spring back into the twist if left once dry.
I untwisted a rib on a build. It was nice and flat and dry. Left it on the bench and a few hours later along came the twist. I tend to fit straight away once unclamped.
I'm rambling on now sorry ;)
#8 Posted : 12 August 2016 11:43:10
Hi Rob.
Look forward to seeing your build.
Ian
RobT
#9 Posted : 12 August 2016 22:37:31
My first, but extremely minor update. The front keel clamped after undergoing a 24 hour soaking in a mixture of water and ammonia. The ammonia hardens the wood fibres as it dries and locks the wood into place.
RobT
#10 Posted : 15 August 2016 16:27:59
Bad news. Things are on hold. I unclamped the keel today and slotted the bulkhead in to check it. I was left with this monstrosity.
There ain't no saving that, so I have a replacement on the way in about a week. Just hope that ones ok. In better news though, I have completed my first deck piece. 3 rows of roughly 1cm staggering. The caulking is a Sharpie chisel tip on one side and one end.
#11 Posted : 15 August 2016 18:27:26
Looking good Rob very nicely done on the corking
#12 Posted : 16 August 2016 00:34:21
The deck is looking very nice Rob, shame about the warpage, I'm sure the next part will be ok
#13 Posted : 16 August 2016 12:41:15
nicely done
#14 Posted : 16 August 2016 22:13:35
Nice work on the decking Rob, looking good...
#15 Posted : 16 August 2016 22:31:29
Nice job of the planking. looking great
RobT
#16 Posted : 02 September 2016 14:59:36
What's your opinion guys.
This is my replacement keel with the bulkhead slotted in. You can see it's a lot straighter than the piece above, but it still looks like there is a very slight bend in it. Do you think it is ok or will it cause me a lot of,problems later on? Would you use it? I'm beginning to think that I'm hoping for a bit too much to get a perfectly straight piece.
greyhawk
#17 Posted : 02 September 2016 16:25:53
Have you watered and pressed it yet for a few days? I've had warp issues with nearly all parts, but most of them could be solved by watering and pressing for some days. Those that reestablished warp again afterwards complied when they were connected to the rest of the build. My bow bulkhead started to turn into a curvehead, but was ok as soon as I glued it to the forecastle deck. My stern was listing to the left by a good 2 centimeters, but complied when I put in the last frame and quarterdeck. The ship itself is perfectly level so far. Hope it keeps that way.
RobT
#18 Posted : 02 September 2016 17:06:27
No I only got it today. I am soaking it now for an hour. I will then clamp between two heavy boards for a couple of days and hope for the best. I don't think its worth getting another replacement as the bend is not too bad and most of the keels may be like that.
greyhawk
#19 Posted : 02 September 2016 17:43:27
#20 Posted : 03 September 2016 09:23:23
Hi Rob, you were right to get a replacement for the first keel. As for the second one, I'd use it but I'd also make sure I placed the whole thing into a build jig before gluing any parts together. Well done she's coming along very nicely.
5 Pages 123>»
