4 Pages 123>»
Tigersharks Cross Section Options
Tigershark
#1 Posted : 06 August 2016 03:04:09
Hi All,
Been a very long time since I last posted, Had the usual things happen in life that saw my models put into storage. Anyhow decided I needed to finish something so I started the cross section awhile back and pulled it out again a couple of weeks ago and now I am determined to finish it.
Tigershark attached the following image(s):
Cheers Tony
Current Build
HMS Victory, HMS Victory Cross Section
Tigershark
#2 Posted : 06 August 2016 04:10:56
Latest photos, Just completed Episode 20 :)
Cheers Tony
Current Build
scraperjawa
#3 Posted : 06 August 2016 04:36:28
That is some really nice work there, Tony. Can't wait to see how this all turns out.
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
z8000783
#4 Posted : 06 August 2016 09:56:50
Groups: Unapproved
Great pictures and great work, Tony. I'm almost tempted.....
#5 Posted : 06 August 2016 10:01:45
Great to see you back modelling again Tony, excellent work on your cross section, she's long fab.....
#6 Posted : 06 August 2016 16:24:53
Some great work Tony,look forward to seeing the finished kit.
#7 Posted : 06 August 2016 16:56:03
#8 Posted : 06 August 2016 18:24:32
Very nice indeed.
Hearing that this is to soon be sold as a complete kit does appeal seeing excellant builds such as yours.
#9 Posted : 06 August 2016 19:37:56
Superb job so far. Great pictures too, really shows off your work to the maximum.
Tigershark
#10 Posted : 07 August 2016 10:53:44
Thanks to everyone for the kind comments, there were a few teething issues. One of my gratings is slightly askew but I think the rest of the build is coming along nicely.I laid the next deck support beams today and found they were short so I had to bring out the masking tape again to bring them together. I decided to do a Day and Night version like Mr T so I could have a go at making everything. I thought that painting the rings and eye bolts on my cannons would be too fiddly for me so I kept them brass. I originally wanted to show my cannons as both run in and out. Unfortunately I overcompensated on breech rope and they just didn't look right when they were run in so I decided to make them all run out, I could have redone them but decided I could show the cannons in the upper deck as run in instead.
I use acrylic craft paint from my local hardware store, Used yellow oxide and red oxide in lieu of yellow and red ochre and happy with the end result. I use water based British paint stains, Teak for the decking, Jarrah for the pumps and suppports and dark walnut for my buckets and barrels.Have nearly completed episode 21. Will post some more photos next week.
Cheers Tony
Current Build
#11 Posted : 07 August 2016 11:00:30
Coming together very nicely Tony looking forward to your next update
Tigershark
#12 Posted : 15 August 2016 09:50:24
Finished my mast and some gunner's tools. The mast came up a little bit shorter than it is supposed to be. I used 2mm whiteboard strip lining tape from an office supply shop for the banding, cost me $4.00 and came up a treat. I have also finished lining the bulwarks and the entry entry ports. Some over vigorous sanding had me knock the cannons and they came a bit loose. Think I managed to secure them again but it is very hard to get into the tight spaces now so be careful if you are doing this model yourself. Getting on with some painting and will then tidy off this deck and start the next one. Nearly finished episode 23 or (143) and started on the bunk supports in 24.
Cheers Tony
Current Build
#13 Posted : 15 August 2016 10:10:38
Looking good Tony . Very nicely done
#14 Posted : 15 August 2016 11:17:19
Your build is coming along great. You are right about those inter deck spaces being tight. I inadvertently knock one of my pump handles off and it was extremely fiddly to get it back in position.
Keep up the good work.
#15 Posted : 15 August 2016 13:26:15
Some very nice work on show, this'll be a really nice display piece when it's finished
#16 Posted : 15 August 2016 15:17:55
This is coming along really nicely and all credit to you..... looks fab...
Tigershark
#17 Posted : 21 August 2016 04:47:31
So latest update and I'm starting to see the light at the end of the tunnel, nearly finished episode 24 or (144) and starting on the next one.I have finished off the middle gun deck and installed my mast.Just need to sand and stain the next deck. I estimate its about 480 hours so far, only another 120 to go.
Cheers Tony
Current Build
#18 Posted : 21 August 2016 08:09:47
Looks good from here
#19 Posted : 21 August 2016 08:22:22
Great progress and looks fabulous.
#20 Posted : 21 August 2016 08:55:36
Fantastic update to your build diary.
I must say this is a great value looking kit with loads of built time for your money.
Looking forward to your next update.
4 Pages 123>»
This page was generated in 0.383 seconds.
