stabilzers Options
max001
#1 Posted : 04 August 2016 12:47:57
Rank: Amateur level 2
Trev,looking at your tail area your elevators, did u have to take a few mills off the elevators to fit, looking, at your markings on the plates near the rudder end it is same as mine after I had to take off about 4mil. max
#2 Posted : 04 August 2016 16:08:11
To save your question being missed, you should place this post as a question in trevs build diary in reply to the relevant post on this
#3 Posted : 04 August 2016 21:11:13
Hi Max001,
Apologies for the delay, in answer to your question regarding the elevators, yes I did have to make small adjustments to each side to ensure of a good fit, this is as all builds are different, then after checking the fit I rivet marked them.
Trev.
