Which glue for wet wood Options
Mr.Quist
#1 Posted : 16 November 2010 18:40:20
Hi shipmates,
my question is simple and may be stupid but I could really need a professional answer.
I am at the stage of starting to plank my launch, my first planks ever.
The mag suggest to soak the planks in water and than glue it to the hull.
Butt.. what kind of glue should I use here?
PVA would maybe take to long to dry and
does superglue stick to wet wood ?
I just wanted to ask before wasting my planks.
Thanks already in advance.
Timm
My build diary here
HMS Victory
Zeptrader
#2 Posted : 16 November 2010 18:50:40
Hi Timm, Ive used super glue on wet wood and in my experience it does stick pretty damn fast and tends to bleed through the wood, especially if the wood is thin, your wood may vary.
I use Alipathic wood glue, sort of yellowish colour to it, it does bond pretty fast, maybe you could pin it while it drys?
Also you could just use clamps of sorts to just hold the wood in position until it drys, then use normal glue.
Mr.Quist
#3 Posted : 16 November 2010 19:10:51
Hi Colin
Thx for that fast response. To be honest I am not a big fan of superglue.
I have tried three different brands so far and they are all way too fast for me,
by the time I got my pieces in position it already sticks like concrete.Mad
That is the reason why I just reordered issue#1 again because I screwed up my 12 pounder several times.Blushing
I read about that stuff every once in a while but I cannot find a german equivalent.
Can recommend a certain brand? Maybe its been sold under the same name over here.
Using clamps or elastic bands will probably the way to go. Still not sure how to fix those plank at the bow.
Timm
My build diary here
HMS Victory
budgie
#4 Posted : 16 November 2010 19:52:07
BigGrin did you try a search for Aliphatic Resin rather than aliphatic glue
mine is by Deluxe Materials
name on bottle Genuine Aliphatic Resin
in small print famous yellow glue for professional use
a common one i have seen is by a company called Titebond (red bottles you want)
http://www.titebond.com.au/products/index.htm
hope this helps in your search
Mr.Quist
#5 Posted : 16 November 2010 20:10:53
Hi budgie
Thank you for that tip. Found this one on amazon here.
How does this stuff react?
I mean how fast is it start to stick?
Timm
My build diary here
HMS Victory
Dontshootme
#6 Posted : 16 November 2010 20:19:58
Timm,the planks on the launch are thin enough to bend without soaking.Just place your thumb nail against your forefinger & drag the plank through(applying pressure) repeat until you have the bend you require.
budgie
#7 Posted : 16 November 2010 20:40:48
BigGrin think you will have plenty of time for positioning
gets tacky in a few minutes so can position plank without it sliding all over the place any excess glue can be wiped away wih a damp cloth
Believed fully bonded strength reached in 6 to 8 hours
If not happy with result wet the glue joints it will soften and you will be able to remove the plank without damage as i have learnt the hard way (not patient enough to get it right 1st time lol)
Cool have you seen Colins Index of Topics there is a section there dedicated to all our worries & woes about the launch build which contains a lot of ideas etc
http://forum.model-space....aspx?g=posts&t=552
Cool Also Mike T did an excellant step by step guide of bending shaping fixing of planks
http://model-space.co.uk...ictory-the-launch-build
Boaz
#8 Posted : 16 November 2010 22:07:24
Hi Timm I use Aliphatic.Totaly new to me.
Nice & fast but you can still shift the timbers a tad if they are not quite in the correct position.Blushing
I fitted my bow planks wet with no problem which was great as they are still nice & flexibleThumpUp
Bob
Mr.Quist
#9 Posted : 17 November 2010 19:55:20
Thanks to all of you guys,
so I will give this alphabetic-something-unspellable-glue a try.
So happy that this is a written conversation, otherwise
someone must have helped me with that knot in my tongue.
@budgie: I must have overreed that "bend-between-fingers" part in Mikes Tutorial.
Hope that the glue will be there by the weekend.
Timm
My build diary here
HMS Victory
This page was generated in 0.158 seconds.
